OCC Bugs in the Bugtracker
gAdlike
Re: OCC Bugs in the Bugtracker
Postby gAdlike » Sat Jan 27, 2018 8:05 am
sgrogan wrote:
Fri Jan 26, 2018 10:52 pm
Kunda1 wrote:
Fri Jan 26, 2018 9:47 pm
For effective collaboration, we need a possibility to replace OCCT in FC third parties
The biggest problem we have is that FreeCAD links against OCCT and nglib (which links against OCCT). So every time we upgrade OCCT we need to upgrade nglib. For porting FreeCAD a newer OCCT this is easy for me. One forum post and usually @wmayer responds with one of his famous "commit xxxxx" posts and FreeCAD is ported. I've compiled FreeCAD locally against self compiled OCCT 7.2 no problems on both Win and Ubuntu. Until recently https://forum.freecadweb.org/viewtopic.php?f=10&t=26278 we've had to port nglib ourselves, and have had trouble getting the patches up-streamed.
It is well-known problem with NetGen library (nglib). For my purposes, I removed all C++11 stuff from the current development version of netgen :D to build it under MSVC2013.
For me, FC building is successful with OCCT7.2 it is also can be launched but it is not possible to use modules with OCCT like step file opening etc. In general, I vote for the migration to MSVC2015 because I use it at home for my pet projects and occt debugging. I used my local OCCT third parties to build with them. It is necessary to check libpack third parties for compilation.
Update: I've built FC with OCCT 7.2.0 using libpack as dependencies, now it is possible to open files :)
Site Admin
Postby wmayer » Sat Jan 27, 2018 11:08 am
A workaround is to disable netgen support when building FreeCAD. This way you are not forced to build netgen/nglib using the newer OCCT version. This results into a somewhat limited FEM workbench but this shouldn't be a problem for the vast majority of OCCT issues as they appear in Part or PartDesign.
NormandC
Postby NormandC » Sat Jan 27, 2018 3:44 pm
The freecad-daily builds PPA for Ubuntu haven't been built with netgen for a long time, since we switched from OCE to OCCT 7.1.0. So far I haven't seen end users ask for it, which I admit is odd...
sgrogan
Postby sgrogan » Sat Jan 27, 2018 3:50 pm
It comes up in the FEM forum. 0.17 can also use gmsh, and FreeCAD uses the executable, so no linking issues. This is why the complaints aren't too loud.
Postby Kunda1 » Mon Feb 05, 2018 5:02 pm
Added issue #3310 to the list
wandererfan
Postby wandererfan » Tue Feb 06, 2018 7:23 pm
Could you also add issue #3332 to your list, please? It isn't drawing much attention on the OCC forum.
Thanks,
wf
Postby Kunda1 » Tue Feb 06, 2018 7:28 pm
Could you also add issue #3332 to your list, please? It isn't drawing much attention on the OCC forum).
Added to Missing upstream tickets section
gAdlike
Postby gAdlike » Wed Feb 07, 2018 4:00 am
Thanks,
wf
I will try to create a corresponding OCCT issue for that problem or investigate what is really expected in that case.
wandererfan
Postby wandererfan » Wed Feb 07, 2018 11:30 am
I can create a ticket on tracker.dev.opencascade.org if that's easier. Didn't want to clutter up the list if my usage was at fault.
wf
gAdlike
Postby gAdlike » Thu Feb 08, 2018 12:26 pm
Corresponding OCCT issue has been created: https://tracker.dev.opencascade.org/view.php?id=29493
