Bug #1818: Bool Op representation error
Postby Kunda1 » Sat Jan 28, 2017 1:49 pm
issue #1818: Bool Op representation error
microelly2 wrote:Description
A Pocket on a Box or the bool difference of two part::Box:
two of the orthogonal views in the 3D windows have errors
hidden inner edges are shown!
The case pad - pocket works fine.
Steps To Reproduce
see the example file
go through all ortho views
OS: Ubuntu 14.04.1 LTS
Version: 0.15.4159 (Git)
Hash: fa3a2a0d3a7a0a619ab6323e236376bb43636e79
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.7.1
quick61 responds:
quick61 wrote:Switch your "View from: X +ve" to "View from: X -ve" and leave "Axis aligned right: Y +ve"
@microelly2 does that help ?
microelly2
Re: Bug #1818: Bool Op representation error
Postby microelly2 » Tue Feb 14, 2017 8:27 am
I will test it again.
microelly2
Postby microelly2 » Thu Feb 16, 2017 2:24 pm
I have the error again when I use front or top view (in orthogonal view).
then I switch to perspective view and back to orthoview and no more error.
it's mystic. :roll:
OS: Ubuntu 14.04.5 LTS
Version: 0.17.10091 (Git)
Build type: None
Hash: 3076b5938f3af5b7a3375c6aa8471bbacb9d6c4a
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
Postby Kunda1 » Thu Feb 16, 2017 2:31 pm
microelly2 wrote:I have the error again when I use front or top view (in orthogonal view).
it's mystic. :roll:
Build type: None
Qt version: 4.8.6
@microelly2 do you mind posting a screenshot to issue #1818 ?
tanderson69
Postby tanderson69 » Thu Feb 16, 2017 2:53 pm
set the transparency to 0
microelly2
Postby microelly2 » Thu Feb 16, 2017 3:02 pm
tanderson69 wrote:set the transparency to 0
the same result :roll:
NormandC
Postby NormandC » Sat Feb 18, 2017 5:05 am
I'm curious, what graphics card/chipset and driver are you using?
I have the same issue. Mine's an Nvidia GeForce GTX 650 Ti I believe, I'm using the nouveau driver and it will tell me no info on the card brand nor model, only "Gallium 0.4 on NVE6".
Postby Kunda1 » Thu Dec 07, 2017 11:46 am
bump
Postby Kunda1 » Sat Jun 09, 2018 1:07 pm
microelly2 wrote:ping
@microelly2 do you have a moment to answer @NormandC's question?
