[SOLVED] Migrating (soon to be deprecated) Drawing WB tickets to TechDraw WB
Jee-Bee
Re: Migrating (soon to be deprecated) Drawing WB tickets to TechDraw WB
Postby Jee-Bee » Wed Feb 01, 2017 7:09 am
wandererfan wrote:1880 - Show/hide drawing template structure
- no plans for this. is it useful for something?
In Pro-E i used this for sending drawings to laser cutting companies. where the last page was an 1:1 model without paper so they can use it as dxf
wandererfan
Postby wandererfan » Wed Feb 01, 2017 2:30 pm
Jee-Bee wrote:In Pro-E i used this for sending drawings to laser cutting companies. where the last page was an 1:1 model without paper so they can use it as dxf
So this is about dxf (or svg,pdf,...) export, not display on screen or print out? That makes some sense.
yorik
Site Admin
Postby yorik » Wed Feb 01, 2017 5:28 pm
Kunda1 wrote:So should I close these for sure?
Yes, thanks!
NormandC wrote:I would tend to close issue #2648 as won't fix.
+1. There has been many discussions about that already, I think it can be closed.
Postby Kunda1 » Wed Feb 01, 2017 11:11 pm
Based on this, does issue #1880 get moved to TD and become a child of issue #2882?
Edit: I fixed the borked issue numbers. Thanks @sgrogan!
sgrogan
Postby sgrogan » Wed Feb 01, 2017 11:33 pm
Kunda1 wrote:Based on this, does issue #1883 get moved to TD and become a child of issue #2883?
I think the issue links are messed up? License issue and Path Contour?
Postby Kunda1 » Wed Feb 01, 2017 11:42 pm
wandererfan wrote:Sorry to take so long to get back to you @kunda1. Here is my take on your list. As others have mentioned, there are no actual plans to retire Drawing at this time.
0143 - Allow moving of views graphically on the page
- in TD
1494 - Add the current view in the orthographic projection tool
- in TD DPG dialog
1679 - Add an action to set orthographic projections as hints for a drawing page
- TD is drag and drop. x/y aren't generally set manually
1688 - Orthographic projection uses more digits behind decimal point for scale than shown in properties
- TD uses global decimals setting
1727 - API function Drawing.projectToDXF
- TD has no projectToDXF API function. no plans for one at this time.
1822 - Scale factor property in drawing page limited to one digit (sometime two)
- TD uses global decimal setting
1863 - Global preference for drawing line width
- Line style/weight preference changes are planned (related 1920,1921)
1867 - Use QtWebKit (QWebView) instead of QtSvg for DW drawing area
- not relevant to TD
1920 - Drawing scale and stroke-dasharray
1921 - Drawing view hidden lines (style) and stroke-dasharray
- Line style/weight preference changes are planned (related 1863)
2004 - Performance regression when more (empty) drawing pages inserted
- empty pages do not seem to be an issue in TD. more non-empty pages will of course slow things down.
2123 - drawing workbench - enable rotation by 3 axis
- you can set the direction of a view to anything you want. Not really applicable to TD
2184 - Drawing template filenames for ISO7200 are numbered consecutively but corresponding files do not exist
- not an issue in TD. different handling of templates.
2283 - Drawing::FeatureViewPart LineWidth should not be scaled
- line widths are not scaled in TD
2620 - Appears in both V0.16 and daily builds Drawing dxf export not working correctly
- no plans for dxf export in TD at this time
2629 - Merge Drawing_dimensioning into Drawing
- no plans to merge Drawing_dimensioning into TD. Some intention to steal good ideas.
2648 - Changing the template in the Drawing-Workbench is not saved
- works in TD
2384 - Drawing dotted lines are inconsistent
- appears to be OCC hidden line issue. resolved in 7.1
2383 - Drawing lines missing or incorrect
- resolved in OCC 7.1
2427 - hidden lines
- resolved OCC 7.1
Hope this helps.
wf
Couple of questions:
1.
@wandererfan mentioned the above tickets. I've started to resolve some of them as you can see from the 1st post which I'm using to keep track of the work. Am I doing it right? If Drawing is not deprecated yet which issues should stay? Do we need to notate them a certain way to indicate that Drawing will be deprecated and attention is now pointed to TechDraw?
2.
@Yorik wrote:
yorik wrote: The DXF-related ones could be gathered under one big "DXF support in techdraw" issue. DXF export doesn't exist in TechDraw yet. That would be a cool feature to work on, if anybody interested :)
I created issue #2882 (DXF support in TechDraw) based on this... :?
But @wandererfan writes:
wandererfan wrote: issue #1727 - API function Drawing.projectToDXF
issue #2620 - Appears in both V0.16 and daily builds Drawing dxf export not working correctly
Please advise.
wandererfan
Postby wandererfan » Thu Feb 02, 2017 1:41 am
Kunda1 wrote:I created issue #2882 (DXF support in TechDraw) based on this... :?
Please advise.
I just meant that I currently had no plans to make a dxf export. If somebody wants it, we should have a feature request in the list for sure.
Postby Kunda1 » Thu Feb 02, 2017 12:29 pm
Please advise.
Thanks for the clarification :)
Postby Kunda1 » Thu Feb 02, 2017 12:33 pm
Should issue #956 "Integrate triplus macro as command into Part/Drawing" (thread) become a Feature Request for TD ?
wandererfan
Postby wandererfan » Thu Feb 02, 2017 3:35 pm
Kunda1 wrote:Should issue #956 "Integrate triplus macro as command into Part/Drawing" (thread) become a Feature Request for TD ?
From a quick review only, TD already does pretty much everything discussed in the thread. I'd say mark it "won't fix" or "resolved in TD".
cron
