[SOLVED] issue with modulo function in expressions
MIngB
Postby MIngB » Sun Jul 16, 2017 7:30 am
it seems that the modulo operator doesn't return the correct dimension.
Actually I think mod(x;y) should do the same as 'x/y-floor(y/y)'
While mod(7mm;3) returns correct 1mm, mod(7mm/3mm) throws an error instead of the correct result 1
I added a FreeCAD Spreadsheet which documents the mod results against the 'x/y-floor(y/y)' results.
ModuloExpr.fcstd
(1.46 KiB) Downloaded 14 times
OS: "NAME=Gentoo"
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.17.11586 (Git)
Build type: Debug
Branch: (HEAD detached at e6b9ec5db)
Hash: e6b9ec5dbcb57db186653d5cd22450418c454439
Python version: 2.7.12
Coin version: 3.1.3
OCC version: 7.1.0
Site Admin
Re: issue with modulo function in expressions
Postby wmayer » Sun Jul 16, 2017 8:14 am
Postby Kunda1 » Tue Jul 18, 2017 11:30 am
PR 884 submitted by @eivindkvedalen
That was quick! Thanks!
Postby Kunda1 » Fri Jul 21, 2017 11:14 am
@MIngB can you test, confirm and prepend [Solved] to this thread ?
