1. Tell user what's going on with a dialog box. Current message is easy to miss and the action creates an empty sketch, so the user might get impression that it all went OK.
2. Use random point to generate the sketch surface OR let user select the 3rd point
I need that feature to work with Silk wb
(1) The message:
Need at least 3 points in order to convert to Sketch
