Issues 1665 & 1666; Symbolic links & backups
Re: Issues 1665 & 1666; Symbolic links & backups
adrianinsaval wrote: Sun Jun 19, 2022 1:08 am do we know some other software's behavior to compare?
Emacs - the mother of free software - creates the backup files in the target directory of the link.
flachyjoe
Post by flachyjoe »
adrianinsaval wrote: Sun Jun 19, 2022 1:08 am There is a mention about absolute paths in your commit, does this affect the relative paths of App_Link?
The opened file name is not changed and the path resolution only occurs after the document content is fixed so the path stored in the document is still the same.
App_Link should work as expected.
All checks have passed so I'm rebasing the branch and removing the PR draft status.
- Flachy Joe -
onekk
Post by onekk »
Edit:
Out of the joke, probably some settings to tune this behaviour will be useful, as due to the size of some FC files, it could be handy to have some settings maybe in Preferences to choose maybe an unified "backup directory" or similar behaviour.
chrisb wrote: Sun Jun 19, 2022 7:57 am
If you don't change his behaviour with some obscure spells in e-lisp :lol:
(setq
 make-backup-files nil
 auto-save-default nil
 create-lockfiles nil)
Only to note that the mother of free software is not so easy to set :-D, and many complains that FC is complicated!!!
Regards
Carlo D.
- Various other stuffs.
flachyjoe
Post by flachyjoe »
@onekk I think we can fix issue #5592 now and tune the backup later as it's more a Feature Request than a Bug.
- Flachy Joe -
onekk
Post by onekk »
flachyjoe wrote: Sun Jun 19, 2022 11:28 am @onekk I think we can fix issue #5592 now and tune the backup later as it's more a Feature Request than a Bug.
Probably yes, my post was only a point of view that when thinking of such things IMHO should be taken in account.
Regards.
Carlo D.
adrianinsaval
Post by adrianinsaval »
fine by me and thinking it through a little more backups in the target directory are probably better since it will be easier to replace the file with a backup, if the backup is in the link directory you'll have to first go to the target anyways to replace unless you want to lose the link
openBrain
Post by openBrain »
IMO, symbolic links are just one aspect of a more larger problem in FC saving strategy.
Another example is respecting the "read-only" parameter of the file. ;)
A bit more explanation.
For example if we have a document named "doc.FCStd", what happens when we save it again is :
* Create the new document as a temporary doc
* Rename "doc.FCStd" as "doc.FCStd1" (all that may vary depending on your backup policy, but not important here)
* Rename the temporary doc as "doc.FCStd"
What would IMO properly solves all kind of issues is to change this to :
* Copy "doc.FCStd" as "doc.FCStd1" (have to manage all backups, not important again)
* Copy temporary doc as "doc.FCStd"
* Delete temporary doc
This would of course increase a bit time needed to save file but should be reasonable.
adrianinsaval
I'm confused about what is the advantage of copy+delete vs move, can you elaborate?
openBrain
Post by openBrain »
adrianinsaval wrote: Tue Jun 21, 2022 1:25 pm I'm confused about what is the advantage of copy+delete vs move, can you elaborate?
Symbolic links are dereferenced with copy but not with move. Not so easy to explain with words, but hopefully this can help :
### Symbolic link dereferencing in read mode
OB@OB-PC:/tmp$ echo "TEST" > test # create a basic file
OB@OB-PC:/tmp$ ln -s test testlnk # create a symbolic link to file
OB@OB-PC:/tmp$ ls -l test*
-rw-rw-r-- 1 OB OB 5 juin  21 15:55 test
lrwxrwxrwx 1 OB OB 4 juin  21 15:56 testlnk -> test
OB@OB-PC:/tmp$ cp testlnk testcp
-rw-rw-r-- 1 OB OB 5 juin  21 15:57 testcp
### We see here that testlnk has been dereferenced with cp function
### testlnk still exists unchanged and testcp is actually a new file being a copy of test
OB@OB-PC:/tmp$ mv testlnk testmv
lrwxrwxrwx 1 OB OB 4 juin  21 15:56 testmv -> test
### We see here that testlnk has NOT ben dereferenced with mv function
### So testlnk doesn't exist anymore and has been renamed testmv
### Symbolic line dereferencing in write mode
OB@OB-PC:/tmp$ echo "TEST_NEW" > test_new # another file
OB@OB-PC:/tmp$ cp test_new testlnk
-rw-rw-r-- 1 OB OB 9 juin  21 16:00 test
lrwxrwxrwx 1 OB OB 4 juin  21 15:59 testlnk -> test
-rw-rw-r-- 1 OB OB 9 juin  21 16:00 test_new
OB@OB-PC:/tmp$ cat test
TEST_NEW
### testlnk still exists unchanged and test content is now a copy of test_new
OB@OB-PC:/tmp$ mv test_new testlnk
-rw-rw-r-- 1 OB OB 9 juin  21 16:00 testlnk
### We see here that testlnk has NOT been dereferenced with mv function
### testlnk no more exists as it was and is now a file
adrianinsaval
got it, but is that default behavior of c++ functions or something implemented by coreutils?
And what about a link to a link? is that handled by your code @flachyjoe ? I tried in bash an it is handled by cp
