Browser inside task panel
I'd like to do a task panel with a form which displays some browser content (the html link to the content will be fix inside the task panel code). The user should be able to navigate through the content inside these form. Does someone has an idea what Qt/PySide form to use and where can I find an example in this regard? All should be done as macro or module in Python and PySide.
The content to display will be similar to this web page: http://autodesk-fusion.partcommunity.com
cheers bernd
EDIT: see https://forum.freecadweb.org/viewtopic. ... 10#p422372
cheers bernd
Re: Browser inside task panel
Qt provides browser widgets you can easily embed. I think there is a difference if you use Qt4 or 5, but for 5 this should work:
http://doc.qt.io/qt-5/qwebengineview.html
Looks like the Open Source Ecology is wanting to use websockets:
https://github.com/damoti/osedev-workbench
http://opensourceecology.org/wiki/OSEDev_Workbench
thanks guys. Found something myself too. https://gist.github.com/justinfx/2af62b1c56174e4b9129 and https://www.youtube.com/watch?v=Gfez0mvwQcg
- microelly2
I had the idea some days ago to run the report view with links back into the 3d scene.
Having a trace in html format in a dockwindow may do this and bring some comfort.
so lets wait for your first prototype.
import FreeCAD
import FreeCADGui
from PySide import QtCore, QtGui, QtWebKit
class TransWindow(QtGui.QDialog):
Example of a partially transparent browser window
Base on screenshot: http://goo.gl/UiULPU
HOME = "http://www.forum.freecadweb.org"
def __init__(self):
super(TransWindow, self).__init__()
self.resize(800,600)
style = QtGui.qApp.style()
self.backButton = QtGui.QToolButton(self)
self.backButton.setIcon(style.standardIcon(style.SP_ArrowLeft))
self.forwardButton = QtGui.QToolButton(self)
self.forwardButton.setIcon(style.standardIcon(style.SP_ArrowRight))
self.reloadButton = QtGui.QToolButton(self)
self.reloadButton.setIcon(style.standardIcon(style.SP_BrowserReload))
self.location = QtGui.QLineEdit(self)
self.webView = QtWebKit.QWebView(self)
self.webView.setSizePolicy(QtGui.QSizePolicy.Expanding, QtGui.QSizePolicy.Expanding)
toolLayout = QtGui.QHBoxLayout()
toolLayout.setSpacing(0)
toolLayout.addWidget(self.backButton)
toolLayout.addWidget(self.forwardButton)
toolLayout.addSpacing(6)
toolLayout.addWidget(self.reloadButton)
toolLayout.addWidget(self.location)
self.layout = QtGui.QVBoxLayout(self)
self.layout.setSpacing(16)
self.layout.addLayout(toolLayout)
self.layout.addWidget(self.webView)
self.setStyleSheet("""
QDialog {
background-color: rgba(50,50,50,35%);
border-radius: 5px;
self.backButton.clicked.connect(self.webView.back)
self.forwardButton.clicked.connect(self.webView.forward)
self.reloadButton.clicked.connect(self.webView.reload)
self.location.returnPressed.connect(self._updateLocation)
self.webView.urlChanged.connect(self._locationChanged)
def showEvent(self, event):
super(TransWindow, self).showEvent(event)
self.webView.load(QtCore.QUrl(self.HOME))
def _updateLocation(self):
text = self.location.text().strip()
if not text:
return
# Being really basic here, for the demo
url = QtCore.QUrl(text)
if not url.scheme():
url.setScheme("http")
self.webView.load(url)
def _locationChanged(self, url):
self.location.setText(url.toString())
mw = FreeCADGui.getMainWindow()
d = QtGui.QDockWidget()
d.setWidget(TransWindow())
mw.addDockWidget(QtCore.Qt.RightDockWidgetArea, d)
less code lines ...
import FreeCAD
import FreeCADGui
def __init__(self):
self.layout.addLayout(QtGui.QHBoxLayout())
Alternatively you i guess could just use Web Workbench for such task.
the file :
A browser widget inside FreeCAD which includes the part above in FreeCAD by click on a text button. This was very helpful https://gist.github.com/webwurst/2203822
import FreeCAD
import FreeCADGui
myhtml = """
<html>
<body>
<h1>Test fuer Web Step Part Importer</h1><br>
<h2><a href="#" onclick="jsWebPartImporter.text('https://forum.freecadweb.org/download/file.php?id=48016')">Press the Button to import the Part in FreeCAD</a></h2>
<h2><a href="#" onclick="alert('Javascript works!')">Java Script Test</a></h2>
</body>
</html>
class WebPartImporter(QtCore.QObject):
def __init__(self, parent=None):
super(WebPartImporter, self).__init__(parent)
@QtCore.Slot(str)
def text(self, pathToStepFile):
print pathToStepFile
import tempfile
import os
stepTmpFd, stepTmpPath = tempfile.mkstemp(suffix=".step")
os.close(stepTmpFd)
import urllib
stepfile = urllib.URLopener()
stepdata = stepfile.retrieve(pathToStepFile, stepTmpPath)
import Part
Part.show(Part.read(stepTmpPath))
FreeCADGui.ActiveDocument.activeView().viewAxonometric()
FreeCADGui.SendMsgToActiveView("ViewFit")
os.remove(stepTmpPath)
def __init__(self):
self.frame = self.webView.page().mainFrame()
self.frame.addToJavaScriptWindowObject('jsWebPartImporter', WebPartImporter())
self.webView.setHtml(myhtml)
another version which uses a step file and and html from my server. Next step is a html from one of the big part supplier I'm in contact with.
import FreeCAD
import FreeCADGui
@QtCore.Slot(str)
import tempfile
import os
os.close(stepTmpFd)
import urllib
import Part
def __init__(self):
self.webView.load(QtCore.QUrl('http://www.b75.ch/download/partimportinfreecad.html'))
