[testing/user input] Blocked Constraint
abdullah
Post by abdullah »
Hi!
I am working on a new constraint codenamed "Blocked Constraint", which just freezes a sketcher edge in place without the need of any constraint. I am thinking of these use cases (many more may arise):
- Constraining certain shapes without bloating the UI (e.g. BSplines).
- Temporarily enabling to block certain geometry while applying constraints to prevent them from moving.
Teaser (fully constraining this sketch with just two tangent and two dimensional constraints):
microelly2
Re: [work in progress] Blocked Constraint
Post by microelly2 »
+1
I'm sure this will simplify the workflow to get "intuitive stable" sketch designs.
abdullah
Post by abdullah »
and there you see... a new use case in 4 minutes... ;)
I have regularly simulated this to keep sketches from jumping during the constraining process: I used to fix certain points with horizontal and vertical distances. If it's more than one point it's tedious and spoils the view.
abdullah
Post by abdullah »
I start to like this feature. However, I will not be able to test it properly much. For that I would ask for volunteers to check this branch:
https://github.com/abdullahtahiriyo/Fre ... constraint
Known issues:
- The icons are [insert bad word here].
- The icons may not display at a reasonable location, or not at all (bspline)
What does it provide:
- Seamless blocking of a geometry element. Including any complex geometry element containing internal alignment geometry (ellipse, bspline,...)
- Seamless redundant/conflict constraint avoidance (so if you block something that is almost fully constrained, it will not complain that the constraints that where there are redundant/conflicting with the newly added "Blocked Constraint").
Do you need a teaser?
Edit: Yes, I am in a rush, so the gif is a little bit...rushed...
Re: [testing/user input] Blocked Constraint
Post by Kunda1 »
Joel_graff wrote:ping
Post by Kunda1 »
abdullah wrote: Thu Dec 21, 2017 9:22 am Known issues:
@abdullah Awesome. Thanks for the teaser! What do you think the icons should look like...got any ideas?
Joel_graff
Post by Joel_graff »
This looks useful. :)
It certainly addresses an issue in the Transpiration workflow, though I'm starting to see how to do it without this sort of feature. But i imagineit would make things simpler
DeepSOIC
Post by DeepSOIC »
Nice feature, can't remember how many times I wanted it :D
triplus
Post by triplus »
Nice!
