Release of v0.17
Re: Release of v0.17
Postby NormandC » Mon Feb 05, 2018 5:25 am
As a quick test, I saved the Third Party Libraries page as simple HTML on my desktop.
Then I ran the following command in the python console:
WebGui.openBrowser('file:///home/normand/Bureau/freecad-about-license.html')
This opened the local html file in FreeCAD's main window. Seems easy enough to run a similar command from a link in About FreeCAD.
Of course it's rather ugly and badly in need of CSS styling. :D
gkv311
Postby gkv311 » Mon Feb 05, 2018 5:46 am
yorik wrote:
Fri Feb 02, 2018 3:54 pm
I added this to the license page of the About dialog:
Would that be enough? I couldn't find any other open-source app that cites all the third-parties libraries used in its about dialog...
Meeting license terms might be painful, especially when using a lot of external libraries.
Here is one extra guide useful for following LGPL:
https://ffmpeg.org/legal.html
In my case, sView lists the major libraries in About dialog, refer them on application about page on web site and tries to elaborate license terms on git (LICENSE file as root information + actual license text files placed near by).
Licenses within About dialog (sView)
Thus, Firefox style, which Open CASCADE CAD Assistant tried to follow (e.g. dedicated HTML page coming with application listing all used components), looks more appropriate for big projects in my opinion. Still, the foundation frameworks of application worth mentioning directly on About page.
This, however, does not answer how to mention 3rdparties of 3rdparties of 3rdparties - almost every library in OSS world nowadays depends on a lot of other projects. It is not that big for Open CASCADE Technology, but it grows big for such things like Qt.
gAdlike
Postby gAdlike » Mon Feb 05, 2018 8:26 am
Third party page looks great but it is better to distribute a copy of license with the software.
Postby yorik » Mon Feb 05, 2018 10:22 am
Normand's solution seems good, but we would need a script that runs at build time to fetch that page from the wiki everytime, to make sure it is using the most up-to-date version. Plus, if FreeCAD is built without webkit, that page will be unavailable.
But since OCC is by far our most important third-party library, and, I believe, the only one that doesn't use standard LGPL (it has an additional clause), we might as well simply add the full OCC license text in our about dialog (an extra tab maybe?). That would be an easy way to solve too... Would that be OK for everybody?
gAdlike
Postby gAdlike » Mon Feb 05, 2018 10:52 am
It will be OK.
Postby wmayer » Mon Feb 05, 2018 1:44 pm
I wouldn't try to fetch the wiki page at build time because you have almost no control if its content has changed in the meantime and if it's still correct. Because the license file will be changed very rarely I vote to add an extra static file to the repository.
Over the weekend I looked closer at how CAD Assistant solved it and I think doing the same way would be the easiest. In a local branch I started to work on it.
Postby NormandC » Tue Feb 06, 2018 3:57 am
That's what I originally had in mind. But I didn't think about what would happen if FreeCAD isn't compiled with webkit. I think the current 0.16 in the Debian repo is like that...
Postby wmayer » Tue Feb 06, 2018 8:38 am
The HTML page with the license texts (that CAD Assistant uses and I want to adjust for FreeCAD) doesn't require any CSS stuff or the like. Therefore, the lightweight QTextBrowser class which is not based on Webkit absolutely suffices. Indeed, with my self-compiled Qt 5.6 on Windows I don't have the Webkit module as the build process always failed. So, a solution that doesn't require Webkit would be the best.
Alternatively, one can also open the system browser and show the license text there but in Qt older than 5.6.2 on Windows there is a bug so that the browser doesn't jump to the anchor of a given url. As a workaround we could also make one HTML file per library.
Postby wmayer » Sun Feb 11, 2018 10:45 am
git commit 7335b3ae adds a new tab to the About dialog with all 3rd party libs and their licences.
kkremitzki
Postby kkremitzki » Sun Feb 11, 2018 4:24 pm
Now that we are in feature freeze can we get a git tag e.g. 0.17-alpha1 which can be used by debian's uscan? This will help me prepare the package for the experimental branch.
