Is there still something to do? IMO, we should finally make the release in this week.
Release of v0.17
Re: Release of v0.17
@wmayer recent crash bug issue #3416
The problem is not in the 3D-View of FreeCAD but in the produced picture needed for documentation, which gives the wrong view. So we will get confusing images in the forum, that were taken with the internal FreeCAD function. Did you check a picture taken with the function: Tools/Save picture...?wmayer wrote: ↑Tue Apr 03, 2018 6:50 pm ulrich1a wrote: ↑
Tue Apr 03, 2018 6:18 pm
There is a problem in the Tools/Save picture... function in regard to datum planes and datum lines. Both are always shown in front of the model in the produced picture, regardless of the position in the 3D-view.
The problem was reported here: https://forum.freecadweb.org/viewtopic. ... 93#p225362
Ulrich
Works for me without problems. So, I assume it's because of the semi-transparency which your driver doesn't support properly.
I got the problem in a Windows installation with an NVidia driver and a Debian installation with a Radeon graphics card.
Ulrich
No, this causes unnecessary bloat that FreeCAD does not use.
Actually all we need for the 0.17 release, are the release versions of OCCT 7.2 and nglib for x64/x32, The debug libs can catch up after the release.
I'm not convinced that a debug Libpack is even necessary for x32? My hope is after 0.17 to provide a complete 11.x-vc12 Libpack with debug libs then switch to 12.x-vc14 based on conda.
Thanks in advance.
"fight the good fight"
ccx is 2.12, I'll see if I can update gmsh to 3.0.6.
Hmm, let's see if I remember how to build this
The images I created for the PartDesign command pages were made with FreeCAD's save picture utility. Check the subtractive primitive pages. My graphics card is an NVidia and I'm using the nouveau driver.ulrich1a wrote: ↑Tue Apr 03, 2018 8:05 pm The problem is not in the 3D-View of FreeCAD but in the produced picture needed for documentation, which gives the wrong view. So we will get confusing images in the forum, that were taken with the internal FreeCAD function. Did you check a picture taken with the function: Tools/Save picture...?
Ulrich
EDIT: the issue is with leaving the background to "current". There is no issue if the background is set to transparent.
Hi Werner, I notice a post about a crash bug here
https://forum.freecadweb.org/viewtopic.php?f=19&t=27764
Don't know if you think it needs to be fixed before release or not.
It happens when a 0 is entered.......
Jim
Yes, of course. I used the Tools/Save picture function.ulrich1a wrote: ↑Tue Apr 03, 2018 8:05 pm The problem is not in the 3D-View of FreeCAD but in the produced picture needed for documentation, which gives the wrong view. So we will get confusing images in the forum, that were taken with the internal FreeCAD function. Did you check a picture taken with the function: Tools/Save picture...?
I have also have an NVidia card namely: GeForce GTX 680 MXI got the problem in a Windows installation with an NVidia driver and a Debian installation with a Radeon graphics card.
NormandC confirmed the problem here: https://forum.freecadweb.org/viewtopic. ... 34#p225462
I can report, that it does only occur with the setting of the current background. It does not occur with white or transparent background.
Tested with a NVidia card Quadro K1200. Just to add this information, in case its a part of the problem. Driver 369.39
Ulrich
Version: 0.17.13433 (Git)
Hash: b45bc4889d390eb50022a49a58c6af80f4a328f5
Python version: 2.7.14
OCC version: 7.1.0
