I installed latest release build, it stop at mod/point only.wmayer wrote: ↑Tue Apr 17, 2018 10:54 am It's rather unusual that it stops in Points because it's a very lightweight library. Stopping in Part might be possible when starting FreeCAD the very first time after a (re)boot because it must load all dependencies (mainly OCCT libs) into memory and this can indeed take a while.
Release of v0.17
Re: Release of v0.17
Any fire-brigading to be done post-release?
And how exactly do you know that it stops in Points? At startup the only two things that happen is to register some file formats and adding an entry to the workbench switcher. At that time it does not even load a dll -- unless it's your default workbench.jaisejames wrote: ↑Fri Apr 20, 2018 3:18 pmI installed latest release build, it stop at mod/point only.wmayer wrote: ↑Tue Apr 17, 2018 10:54 am It's rather unusual that it stops in Points because it's a very lightweight library. Stopping in Part might be possible when starting FreeCAD the very first time after a (re)boot because it must load all dependencies (mainly OCCT libs) into memory and this can indeed take a while.
In startup, as shown in attachment, it stops there for 12 sec & continues. You can see that I can take screen shot over there[attachment]. Any method to Profile startup?
Still It is wonderful release so much improvement to last 0.16. Thank for developers for that.
My Info:
OS: Windows 7
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.17.13515 (Git)
Branch: releases/FreeCAD-0-17
Hash: e17b340949b75a226cc7d89989b0aa238ccfc75f
Python version: 2.7.14
OCC version: 7.2.0
Locale: English/India (en_IN)
My Info:
OS: Windows 7
OCC version: 7.2.0
- During startup freecad loading.jpg (27.95 KiB) Viewed 1992 times
As you can see in the message it says "Initializing C:\Program Files\FreeCAD 0.17\Mod\Points... done" which means that it has successfully added the Points module. So, the culprit must be the module that will be initialized after the Points module.In startup, as shown in attachment, it stops there for 12 sec & continues. You can see that I can take screen shot over there[attachment]. Any method to Profile startup?
From startup log, problematic modules may be Draft & Arch. They are loaded after Point & Part
I updated to latest. Now it stops in Point & Part done loading
OS: Windows 7
Version: 0.17.13519 (Git)
OCC version: 7.2.0
OS: Windows 7
OCC version: 7.2.0
What does it say?jaisejames wrote: ↑Tue Apr 24, 2018 7:38 amFrom startup log, problematic modules may be Draft & Arch.
When downloading 0.17 from the dowloads page https://freecadweb.org/wiki/Download the linked file is FreeCAD_0.17.13509.glibc2.17-x86_64.AppImage and not the updated FreeCAD-13519.glibc2.17-x86_64.AppImage, is this intentional?
Need help? Feel free to ask, but please read the guidelines first
It was an oversight (I fixed it a few days ago). Why would it be intentional?
Perfect, thanks.
Might be some problem with the new image?
