Release of v0.17
jaisejames
Re: Release of v0.17
Postby jaisejames » Tue Apr 10, 2018 10:27 am
I have installed Freecad in windows[freshly re-installed OS]. During startup, it is stopping in Mod/Point & Mod/Part more than 10sec. I didn't have issue in arch & Ubuntu version. Any body having issue?
My info:
OS: Windows 7
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.17.13509 (Git)
Branch: releases/FreeCAD-0-17
Hash: 0258808ccb6ba3bd5ea9312f79cd023f1a8671b7
Python version: 2.7.14
OCC version: 7.2.0
Locale: English/India (en_IN)
triplus
Postby triplus » Tue Apr 10, 2018 12:45 pm
Congratulations!
easyw-fc
Postby easyw-fc » Wed Apr 11, 2018 9:13 pm
Hi to all,
I have to report a serious bug in STEP exporter on stable release FreeCAD-0.17.13509.0258808
When exporting a hierarchical STEP, nothing get exported and the result file is empty.
Everything worked fine until release FreeCAD_0.17.13488
Please find attached a STEP file to test (exported with FreeCAD-0.17-13488)
d488.step
(955.56 KiB) Downloaded 29 times
and the empty STEP file exported by FreeCAD-0.17-13509
d509.step
(1.63 KiB) Downloaded 24 times
Same issue with FreeCAD_0.18.13516
(tested on Win 10-64 & Ubuntu 16.04-64)
I don't know which is the commit that broke the exporting...
I'm sorry I missed that issue before the stable came out...
EDIT:
step to reproduce the bug:
Open the hierarchical STEP file 'd488.step' in FC0.17-509 and select the Part top level container, then export the selection as STEP through the file menu.
The exported STEP file 'd509.step' will be empty.
Those exporting operation worked fine at least until FC0.17-13488 (I don't have intermediate releases between tose two).
Same issue on FC0.18-13516
bug reported here
https://freecadweb.org/tracker/view.php?id=3426
Version: 0.17.13488 (Git)
Hash: 2891173923bcecaace64e0544f5773facbdef436
OCC version: 7.1.0
OCC version: 7.2.0
EDIT2:
This seems related to OCC7.2 and FC exporting code, because I verified this issue also on FC0.17-13452 Conda build, where the FC release was prior to 13488, but OCC was already 7.2
Version: 0.17.13452 (Git)
Hash: 34633c144de9133c1f9aeb7da783f369cae9bfaf
Python version: 3.6.4
Qt version: 5.6.2
OCC version: 7.2.0
bejant
Postby bejant » Thu Apr 12, 2018 1:09 am
I can report that the Export works correctly using OCC 7.1.0:
OS: Ubuntu 16.04.4 LTS
Build type: None
Python version: 2.7.12
OCC version: 7.1.0
Using the hierarchical d488.step file included in issue #3426 (which I presume is the same as in the preceding post), the resulting .step export is too large to upload to the forum.
Edit = typo that broke my link to the Mantis ticket.
NormandC
Postby NormandC » Thu Apr 12, 2018 2:55 am
So you didn't update your freecad-daily and freecad-stable packages yet? They are now both based on OCCT 7.2.0.
easyw-fc
Postby easyw-fc » Thu Apr 12, 2018 7:44 am
may we switched to OCC7.2 too fast... it was in between 13488 and 13509 for win (only about a week) ... very little time to test for including them in the stable ...
As a side note we probably would need to add a testing check for STEP functionality in FC build...
bejant
Postby bejant » Thu Apr 12, 2018 1:41 pm
Yes, that's correct - the last time I updated was a few days ago.
NormandC
Postby NormandC » Thu Apr 12, 2018 2:10 pm
While we switched to OCCT 7.2 for the Ubuntu PPA over the weekend, 0.17_pre Mac builds had been based on it for a long time, and developers were already using 7.2.0 as well.
Site Admin
Postby wmayer » Tue Apr 17, 2018 10:54 am
jaisejames wrote:I have installed Freecad in windows[freshly re-installed OS]. During startup, it is stopping in Mod/Point & Mod/Part more than 10sec. I didn't have issue in arch & Ubuntu version. Any body having issue?
It's rather unusual that it stops in Points because it's a very lightweight library. Stopping in Part might be possible when starting FreeCAD the very first time after a (re)boot because it must load all dependencies (mainly OCCT libs) into memory and this can indeed take a while.
Marco_T
Postby Marco_T » Fri Apr 20, 2018 12:20 pm
I think we need update these pages:
https://forum.freecadweb.org/viewtopic.php?f=3&t=2264
Make sure you are using the latest version (0.16 Revision 6712).
even if (it seems) few people read it :roll:
Marco_T
