More Weird Behavior from the Draft WB: Memory Leak?
cflin
Postby cflin » Wed Feb 07, 2018 8:36 am
Last year, I posted about the problem of snap points in the Draft WB (the don't work on multi-parts). However, in the most recent release of FC17 (as of Feb. 7, 2018), I observed the following:
  1. The snap points seem to work even on a multi-part if there is no Origin block (they still don't if there is an Origin block).
  2. I observed what seems to be a serious memory leak when I use the Draft WB. Although I did not put FC17 through valgrind or any other tool to verify this observation, I just know it's a memory leak because I start with a small file (only a couple of MB) and once I use the Draft WB a couple of times, the memory consumption of FC17 grows to over 11GB! I save the file, shut down FC17, restart it, re-import the same file, and the memory footprint of FC17 is negligible until I use the Draft WB again...
I am running the latest version of FC17, as I said, on 64-bit Ubuntu 16.04.3LTS.
It seems somebody is working on the Draft WB!
Re: More Weird Behavior from the Draft WB
Postby chrisb » Wed Feb 07, 2018 8:42 am
I observed what seems to be a serious memory leak when I use the Draft WB. Although I did not put FC17 through valgrind or any other tool to verify this observation, I just know it's a memory leak because I start with a small file (only a couple of MB) and once I use the Draft WB a couple of times, the memory consumption grows to over 11GB!
Can you please show your complete FreeCAD infos from the about dialog? It's important to know exactly which system you use. And can you please give a - preferably short - list of steps which clearly show the issue.
cflin
Re: More Weird Behavior from the Draft WB: Memory Leak?
Postby cflin » Wed Feb 07, 2018 8:55 am
Boy, this forum is very quick! I recalled my posting to add this info, and while I was doing that, you responded. I made some other changes to the HTML tags to improve readability.
Basically, I import an existing small file and then use the Draft WB. As it hunts for snap points, the memory footprint grows very rapidly. To reproduce the presumed fault, just invoke the dimensioning tool, hunt for a couple of snap points, release the dimensioning tool, and invoke it again. On my setup, each cycle of invocation of the dimensioning tool of the Draft WB increases the memory footprint of FC17 by many GB.
Here is what "About" says:
OS: Ubuntu 16.04.3 LTS
Version: 0.17.13217 (Git)
Build type: None
Hash: 89275766de909a5c1f36e962806dc7b4a0b0f47b
Python version: 2.7.12
OCC version: 7.1.0
Yes, it was dumb not to post system info the first time. But it is very late for me...
Postby chrisb » Wed Feb 07, 2018 10:20 am
I did the following:
- Start FreeCAD from console. (Output redirection of stderr to a file didn't work as expected, the counter was missing)
- Switch To Part
- new document
- Create Cube, leave default values
- switch manually to Draft, recompute(), switch to Part, recompute()
- process size at this moment: 196612
- execute the following in Python console:
for i in range (1,1000):
  App.Console.PrintError(i)
  Gui.activateWorkbench("PartWorkbench")
  Gui.activateWorkbench("DraftWorkbench")
- while running I checked manually the process size, the biggest being 204604
- the output shows the following:
maccb:Desktop cb$ FreeCAD.app/Contents/MacOS/FreeCAD
FreeCAD 0.17, Libs: 0.17R13217 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2018
Cannot find icon: cloneddollyRMv3
Draft workbench activated
Draft workbench deactivated
1Draft workbench deactivated
2Draft workbench deactivated
3Draft workbench deactivated
4Draft workbench deactivated
5Draft workbench deactivated
6Draft workbench deactivated
7Draft workbench deactivated
8Draft workbench deactivated
9Draft workbench deactivated
10Draft workbench deactivated
11Draft workbench deactivated
2018-02-07 11:13:26.580 FreeCAD[46903:5377730] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
Unhandled unknown exception caught in GUIApplication::notify.
2018-02-07 11:13:26.589 FreeCAD[46903:5377730] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 11:13:26.599 FreeCAD[46903:5377730] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 11:13:26.604 FreeCAD[46903:5377730] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 11:13:26.609 FreeCAD[46903:5377730] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 11:13:26.621 FreeCAD[46903:5377730] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 11:13:26.626 FreeCAD[46903:5377730] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
122018-02-07 11:13:26.803 FreeCAD[46903:5377730] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 11:13:26.813 FreeCAD[46903:5377730] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 11:13:26.826 FreeCAD[46903:5377730] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 11:13:26.846 FreeCAD[46903:5377730] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 11:13:26.860 FreeCAD[46903:5377730] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 11:13:26.868 FreeCAD[46903:5377730] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 11:13:26.878 FreeCAD[46903:5377730] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 11:13:26.883 FreeCAD[46903:5377730] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 11:13:26.888 FreeCAD[46903:5377730] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 11:13:26.949 FreeCAD[46903:5377730] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 11:13:26.955 FreeCAD[46903:5377730] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 11:13:26.958 FreeCAD[46903:5377730] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 11:13:26.963 FreeCAD[46903:5377730] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
*** Abort *** an exception was raised, but no catch was found.
	... The exception is:SIGSEGV 'segmentation violation' detected. Address 0
A different test showed even some recoveries from exceptions but crashed in the end as well:
12Draft workbench deactivated
13Draft workbench deactivated
14Draft workbench deactivated
15Draft workbench deactivated
16Draft workbench deactivated
17Draft workbench deactivated
18Draft workbench deactivated
19Draft workbench deactivated
20Draft workbench deactivated
21Draft workbench deactivated
22Draft workbench deactivated
23Draft workbench deactivated
24Draft workbench deactivated
25Draft workbench deactivated
26Draft workbench deactivated
27Draft workbench deactivated
2018-02-07 10:17:49.757 FreeCAD[1599:5052020] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 10:17:49.761 FreeCAD[1599:5052020] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 10:17:49.767 FreeCAD[1599:5052020] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 10:17:49.771 FreeCAD[1599:5052020] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 10:17:49.774 FreeCAD[1599:5052020] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 10:17:49.781 FreeCAD[1599:5052020] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 10:17:49.784 FreeCAD[1599:5052020] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
282018-02-07 10:17:49.889 FreeCAD[1599:5052020] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
29Draft workbench deactivated
30Draft workbench deactivated
31Draft workbench deactivated
32Draft workbench deactivated
33Draft workbench deactivated
34Draft workbench deactivated
35Draft workbench deactivated
2018-02-07 10:17:51.844 FreeCAD[1599:5052020] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 10:17:51.848 FreeCAD[1599:5052020] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 10:17:51.855 FreeCAD[1599:5052020] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 10:17:51.861 FreeCAD[1599:5052020] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 10:17:51.865 FreeCAD[1599:5052020] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 10:17:51.873 FreeCAD[1599:5052020] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 10:17:51.876 FreeCAD[1599:5052020] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
362018-02-07 10:17:51.979 FreeCAD[1599:5052020] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
37Draft workbench deactivated
38Draft workbench deactivated
39Draft workbench deactivated
40Draft workbench deactivated
41Draft workbench deactivated
42Draft workbench deactivated
43Draft workbench deactivated
44Draft workbench deactivated
45Draft workbench deactivated
46Draft workbench deactivated
47Draft workbench deactivated
48Draft workbench deactivated
49Draft workbench deactivated
50Draft workbench deactivated
51Draft workbench deactivated
52Draft workbench deactivated
53Draft workbench deactivated
54Draft workbench deactivated
55Draft workbench deactivated
56Draft workbench deactivated
57Draft workbench deactivated
58Draft workbench deactivated
59Draft workbench deactivated
60Draft workbench deactivated
61Draft workbench deactivated
62Draft workbench deactivated
63Draft workbench deactivated
64Draft workbench deactivated
65Draft workbench deactivated
662018-02-07 10:18:00.901 FreeCAD[1599:5052020] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 10:18:00.908 FreeCAD[1599:5052020] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 10:18:00.916 FreeCAD[1599:5052020] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 10:18:00.921 FreeCAD[1599:5052020] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 10:18:00.924 FreeCAD[1599:5052020] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 10:18:00.929 FreeCAD[1599:5052020] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 10:18:00.932 FreeCAD[1599:5052020] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 10:18:00.935 FreeCAD[1599:5052020] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 10:18:01.039 FreeCAD[1599:5052020] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
67Draft workbench deactivated
68Draft workbench deactivated
69Draft workbench deactivated
70Draft workbench deactivated
71Draft workbench deactivated
72Draft workbench deactivated
73Draft workbench deactivated
74Draft workbench deactivated
75Draft workbench deactivated
76Draft workbench deactivated
77Draft workbench deactivated
78Draft workbench deactivated
79Draft workbench deactivated
80Draft workbench deactivated
81Draft workbench deactivated
82Draft workbench deactivated
83Draft workbench deactivated
84Draft workbench deactivated
85Draft workbench deactivated
86Draft workbench deactivated
872018-02-07 10:18:08.370 FreeCAD[1599:5052020] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 10:18:08.376 FreeCAD[1599:5052020] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 10:18:08.383 FreeCAD[1599:5052020] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 10:18:08.386 FreeCAD[1599:5052020] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 10:18:08.390 FreeCAD[1599:5052020] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 10:18:08.395 FreeCAD[1599:5052020] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 10:18:08.398 FreeCAD[1599:5052020] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 10:18:08.402 FreeCAD[1599:5052020] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
2018-02-07 10:18:08.516 FreeCAD[1599:5052020] *** Assertion failure in -[NSMenu insertItem:atIndex:], /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppKit/AppKit-1561.20.106/Menus.subproj/NSMenu.m:725
OS: Mac OS X
Branch: (HEAD detached at 8927576)
Python version: 2.7.14
Qt version: 5.6.2
OCC version: 7.1.0
Postby chrisb » Wed Feb 07, 2018 11:34 am
Ubuntu works better, but the process size is increasing
I slightly simplified the test and did nothing but switching workbenches:
The process size somehow corresponds with the number of double-switches:
500 switches yield a size of 536108
600 switches yield a size of ~ 590000
750 switches yield a size of ~ 622544
somewhere between 700 and 800 double switches it became very slow, almost 45 seconds for 10 double switches, the last 10 took almost a minute.
After the loop ended the process did nothing for quite a while at a size of 620336, FreeCAD was still not responding. Finally the GUI became active again, the process size stayed at 620336
Build type: None
OCC version: 7.1.0
Postby chrisb » Wed Feb 07, 2018 11:38 am
There is something else peculiar with workbench switching: When I switch from PartDesign Workbench to some other Workbench the Python console tells
import PartDesignGui
on every switch away from PartDesign.
Site Admin
Postby wmayer » Wed Feb 07, 2018 12:39 pm
My observation with:
OS: Windows 7
Version: 0.17.13208 (Git)
Hash: 1402e39ba0393d309f372f490ec77f1015be1c1a
Python version: 2.7.8
OCC version: 7.0.0
I'm not sure if just loading the workbench causes the memory consumption reported by cflin. My test is as follows:
  1. Create a standard box in Part workbench
  2. Switch to Draft workbench. At this point I have a total size of 165 MB
  3. Activate the dimension command
  4. Do nothing but hovering over the box. You will see that the snap tool shows and hides some extra stuff in the 3d view
  5. After playing a while (e.g. 30 sec) the total size of consumed memory increased to 300 MB
I cannot confirm the huge number of 11GB but I can confirm almost doubled memory consumption after relative short time.
Site Admin
Postby wmayer » Wed Feb 07, 2018 12:41 pm
That's not a problem at all. Once the PartDesignGui module is loaded a second call is (more or less) a no-op.
Site Admin
Postby wmayer » Wed Feb 07, 2018 12:45 pm
yorik
Site Admin
Postby yorik » Fri Feb 09, 2018 11:08 am
Strange thing... Indeed it happens with all Draft tools (and Arch tools that depend on it too). The problem is very likely inside the snapping stuff. Also if there is no object in the document, the memory consumption still raises, but very slowly. If there is an object to hover on, memory consumption raises much faster.
Will do some more experiments, but very probably some stuff gets stored inside the Draft Snapper object, which stays existing over the whole freecad session...
