More Weird Behavior from the Draft WB: Memory Leak?
triplus
Re: More Weird Behavior from the Draft WB: Memory Leak?
Post by triplus »
If i repeat the rectangle test as described earlier. I can confirm the amount of memory increase involved is nowhere near the levels as seen before.
Post by wmayer »
yorik wrote: Wed Feb 21, 2018 4:05 pm I was able to narrow down the memory leak further, it seems to happen inside pivy. For example, this creates a ~30Mb memory increase (takes a couple of minutes to complete):
from pivy import coin
c = coin.SoCoordinate3()
pts = [[0.0,0.0,0.0],[1.0,1.0,1.0]]
for i in range(1000000):
    c.point.setValues(pts)
Can someone else can test the code snippet above and confirm the memory being eaten?
I can confirm that the memory usage increases by ~30MB but the conclusion is wrong that it's caused by pivy. You achieve the same effect when you simply write:
r=range(1000000)
when deleting r then the memory usage goes down by ~10MB. But when running the garbage collector then there is no memory overhead at all.
del r # frees ~10MB
import gc
gc.collect()  # frees the remaining ~20MB
So, if you write
import gc
gc.collect()
you only allocate the 30 MB temporarily. There is also a way to avoid the tmp. consumption completely:
i=0
while i<1000000:
    i=i+1
What remains is that the execution is pretty slow. The same snippet in C++ looks like
    SbVec3f pts[2] = {SbVec3f(0.0,0.0,0.0),SbVec3f(1.0,1.0,1.0)};
    SoCoordinate3* c = new SoCoordinate3();
    for (int i=0;i<1000000;i++)
        c->point.setValues(0,2,pts);
and it's done more or less immediately.
Post by yorik »
Wow thanks... that's a real programming lesson!
I thought that when you existed a function, all variables created inside would automatically be deleted by the automatic garbage collection that I always heard python had... And in our case, the problem is not that setValues() runs inside a big loop, but rather that it is called on every mouse move... So in theory the function that contains the setValues() statement is exited each time... I still don't understand...
But it occurs to me now, that actually the whole draft snap queue is triggered on every mouse move, and that you can therefore have several concurrent queues running... That sounds like extremely bad programming :oops: I'll experiment letting it run only one concurrent at a time.
Post by yorik »
Ok I committed a small change that optimizes snapping a lot, but the memory leak is still there... :( Don't know where it comes from if not from pivy... I'll investigate more then
Post by wmayer »
One remark about the speed issue. I first thought that it could be caused by the SWIG generated code which does quite a lot of type checking and conversions and so on. But when changing the code to:
point = coin.SoMFVec3f()
i=0
while i<1000000:
    i=i+1
then it only takes a couple of seconds to execute. And when changing the original example to
point = c.point
i=0
while i<1000000:
    i=i+1
then it also finishes after a couple of seconds. So, the conclusion is that accessing the field of an Inventor node in pivy is very expensive.
Post by yorik »
Aha that's a very good find... Too much to touch in all Draft to do that now, so close to the release I think, but I'll do that right after. Could give a massive speed gain...
Post by Kunda1 »
Is there a logical conclusion to issue #3340 then?
Post by yorik »
Not really, but I'll test that again
