Will do, Thanks for looking.
Win gitpython & add-ons installer tool
Re: Win gitpython & add-ons installer tool
No luck
File "C:\Users\Chris\GitHub\FCAutoBuild\var\FreeCAD_0.17.13354_x64_dev_win\Mod\AddonManager\AddonManager.py", line 340, in remove
shutil.rmtree(clonedir)
File "C:\Users\Chris\GitHub\FCAutoBuild\var\FreeCAD_0.17.13354_x64_dev_win\bin\lib\shutil.py", line 261, in rmtree
rmtree(fullname, ignore_errors, onerror)
File "C:\Users\Chris\GitHub\FCAutoBuild\var\FreeCAD_0.17.13354_x64_dev_win\bin\lib\shutil.py", line 266, in rmtree
onerror(os.remove, fullname, sys.exc_info())
File "C:\Users\Chris\GitHub\FCAutoBuild\var\FreeCAD_0.17.13354_x64_dev_win\bin\lib\shutil.py", line 264, in rmtree
os.remove(fullname)
WindowsError: [Error 5] Access is denied: 'C:\\Users\\Chris\\AppData\\Roaming\\FreeCAD\\\\Mod\\assembly2\\.git\\objects\\pack\\pack-7ee4ad020df47103a0499d7fde18b51cc1079f5e.idx'
Godd answer here: https://stackoverflow.com/questions/482 ... in-windows
I will try to implement it.
"fight the good fight"
On Linux the directory gets removed and shutil.rmtree() doesn't care about if any files are read only in it. On Windows a directory with read only file will produce the mentioned error. This works differently yes. On this two platform.
I did a few more tests with Git directly. Indeed there will likely always be some read only files involved. I updated the branch. Pressing on the Remove button should now work on Windows?
Works good on Windows, thanks.
AddonManager doesn't use the python git module for uninstall so my earlier hack for the environment isn't need for uninstall.
You're welcome.
Correct. I took a quick look and there is one more occurrence of shutil.rmtree() and a shutil.move(). Both related to i guess backup folder functionality. It would likely make sense to investigate on how to invoke this functionality and test this area too. On what happens when read only files are involved. As for shutil.rmtree() that will likely fail. I can add the same fix. As for shutil.move() i am not sure.AddonManager doesn't use the python git module for uninstall so my earlier hack for the environment isn't need for uninstall.
In addition what are your plans. To provide GitPython by default in Windows installer? And what about Git executable. User would have to install it manually? Will end users do that or just continue to use "ZIP download" method? And a bit unrelated question. Based on your info on Windows the path to Mod folder isn't guaranteed to be in ASCII character set. Can some users on Windows expect issues with FreeCAD modules and macros because of that?
This was my original intention, but now I'm not so sure because of the unicode problem. I can add an option to the installer to install the git executable, like we do with the VS re-distributable package, only make it optional. The zip option works well on Windows, but update will re-install regardless if an update is available.
It comes down to the users Windows %username% It looks like FreeCAD pre-pends sys.path to PATH which ends up unicode encoded. I don't know if encoding in utf-8 like my hack does will cause problems somewhere else. I believe the root cause is when unicode is passed to Popen (or subprocess).
OK the first thing i did is i created the PR:
https://github.com/FreeCAD/FreeCAD/pull/1357
Mentioned additional shutil.rmtree() and a shutil.move() lines are related to ZIP download. And there read only files are not expected. Therefore i didn't change anything there for now. In theory if user would use GitPython to install a module. And after remove GitPython/Git executable. ZIP download option would be used again. And then likely read only files would be involved in the existing module folder. Pressing on Remove button would still work though. And after using the ZIP download option would succeed again.
https://github.com/gitpython-developers ... git/cmd.py
You will find a line:
Additional line after it:
Should likely fix the mentioned issue on your side.
P.S. Don't know though what to expect in scenarios where for example user name contains non-ASCII characters. You can i guess test that too. If you find the proposed solution feasible.
Nice.
FreeCAD Python 3 build might remove this particular issue (maybe it would introduce others). As for Python 2. What you could test (if you are interested) is to add a small patch in GitPython. Around the line 700:This was my original intention, but now I'm not so sure because of the unicode problem.
env = os.environ.copy()
env['PATH'] = str(env['PATH'])
Thanks. I haven't had time to test yet, but I will. I need to find a way to safely setup other usernames/langs/locales without borking my dev machine.
Take your time.
P.S. Generally speaking likely it will make sense for you to be able to easily test for possible issues (Py2/Py3) in this area. Not just GitPython related.
I can do this now, on Win (PY3.6 + QT5), thanks to @looo. Not so easy to distribute yet, but maintainable locally. I can also cross against Ubuntu 14.04 (PY3.4+QT4), again not so easy to distribute, but maintainable locally.
I do it locally and not in a VM, so I must be careful
