Solution for one instance of the Topological Naming Problem
Discussions about the wiki documentation of FreeCAD and its translation.
dprojects
Post by dprojects »
Edit by moderator chrisb: I have split this part of the discussion from https://forum.freecadweb.org/viewtopic. ... 50#p617032, because it discusses especially how this wiki page should be handled.
What is the Topological Naming Problem? why you can't store key before operation? I don't get it?
Thanks
Darek
github.com/dprojects
workbench for woodworking is available at: github.com/dprojects/Woodworking
Re: Topological Naming, My Take
dprojects wrote: Mon Aug 15, 2022 9:39 pm What is the Topological Naming Problem?
Topological naming problem
C_h_o_p_i_n
Post by C_h_o_p_i_n »
[Deleted] - du to no belonging to this thread after splitting and moving the thread by chrisb.
dprojects
Post by dprojects »
I added the page with solution to wiki at: https://wiki.freecadweb.org/TNP_solution
Thanks
Darek
mfro
Post by mfro »
That script is pretty useless without the corresponding FreeCAD model?
Cheers,
Markus
dprojects
Post by dprojects »
mfro wrote: Tue Aug 16, 2022 9:39 am That script is pretty useless without the corresponding FreeCAD model?
Seriously? The Topological_naming_problem page describe how to create the Pads... only thing added is Constrains to be able to resize the model from python script. You can even make GUI for that and move it back and forward and changing the face name like this, and the recompute will be ok.
I am not sure if the wiki support adding FreeCAD files so I add this here, hopefully I didn't delete it ;-) I am not good at wiki editing. Wiki is not good to keep code, especially python code where indentation is important.
TNP.FCStd
(25.81 KiB) Downloaded 93 times
Thanks
Darek
Roy_043
Post by Roy_043 »
dprojects wrote: Tue Aug 16, 2022 10:40 amSeriously?
The name of the page suggests that this is THE solution for the TNP problem. Is this really what you want to convey?
dprojects
Post by dprojects »
I don't understand what you asking for. You asking why I posted this solution for free? or why this wiki page was not created before?
Thanks
Darek
Roy_043
Post by Roy_043 »
My point is that what you are proposing is not the solution of the TNP problem.
mfro
Post by mfro »
dprojects wrote: Tue Aug 16, 2022 10:40 am... The Topological_naming_problem page describe ...
The Topological_naming_problem wiki page describes the problem with one single example of TNP.
TNP however has many more different incarnations (e.g. a sketch referring external geometry or a plane attached to a face).
Your script solves this one single example of TNP (which is fine of course), but not TNP in general.
Cheers,
Markus
