porting to smesh 8.3
looo
Postby looo » Thu Mar 29, 2018 9:52 am
as pyocct uses a newer smesh than freecad, and therefor if both libraries are installed in the same environment both libraries are not working properly.
So I would like to use smesh as an external library. But therefor we have to port to the newer smesh.
As I am not very comfortable with c++ I will put here some question to solve problems that come up during the porting.
What has been done so far:
- build external smesh as a conda-package https://github.com/LaughlinResearch/SMESH
- switch cmake options to use external smesh:
      -D FREECAD_USE_EXTERNAL_SMESH=ON \
      -D SMESH_INCLUDE_DIR=$PREFIX/include/smesh \
- make some modification to freecad: https://github.com/looooo/FreeCAD/tree/smeah8.3
please help with my conda-packaging efforts: https://liberapay.com/looooo/
minimalistic blog: https://looooo.github.io/mini-blog/
looo
Re: porting to smesh 8.3
Postby looo » Thu Mar 29, 2018 9:56 am
So first problem:
~/projects/FreeCAD/src/Mod/MeshPart/App/Mesher.cpp:413:55: error: invalid use of incomplete type ‘class SMESHDS_Mesh’
     SMDS_FaceIteratorPtr aFaceIter = mesh->GetMeshDS()->facesIterator();
https://github.com/looooo/FreeCAD/blob/ ... p#L413L414
Site Admin
Postby wmayer » Thu Mar 29, 2018 12:33 pm
Look at the external smesh lib and check which header offers the class SMESHDS_Mesh. This header must then be included in Mesher.cpp
looo
Postby looo » Thu Mar 29, 2018 12:39 pm
thanks, it seems to be a problem with definitions. HAVE_NETGEN wasn't set if FREECAD_USE_EXTERNAL_SMESH was enabled. Also I don't know if
BUILD_FEM_NETGEN should be enabled or not.
looo
Postby looo » Thu Mar 29, 2018 1:33 pm
next one:
~/projects/FreeCAD/src/Mod/Fem/App/HypothesisPy.cpp:147:5: error: ‘class SMESH_Hypothesis’ has no member named ‘SetParameters’
any ideas where SMESH_Hypothesis::SetParameters is defined?
looo
Postby looo » Thu Mar 29, 2018 2:38 pm
I think I found this one, and it is not defined anymore in smesh8.3.
It seems everything is compiling now. But there is one linker problem, introduced by a workaround:
CMakeFiles/Fem.dir/FemMesh.cpp.o: In function `Fem::FemMesh::getGenerator()':
FemMesh.cpp:(.text+0xe09): undefined reference to `Fem::FemMesh::_mesh_gen'
this belongs to this workaround:
https://github.com/looooo/FreeCAD/commi ... 8736b0R491
kkremitzki
Postby kkremitzki » Thu Mar 29, 2018 5:01 pm
I was interested in tackling this during GSoC if I get in but I'm glad you're tackling it in advance! I can help on the "getting this into Debian" part as well as following along with your work on it.
looo
Postby looo » Thu Mar 29, 2018 5:28 pm
I guess there is way too much work for the summer anyway ;) I started this because I want to use pyocct and freecad together.
looo
Postby looo » Fri Mar 30, 2018 5:00 am
I solved my last problem by defining the static member to 0 in the cpp file. So now FreeCAD compiles, but meshing a cube results in a crash:
#0  /lib/x86_64-linux-gnu/libc.so.6(+0x354b0) [0x7f4858e8f4b0]
#1  0x7f47d5d926a7 in Standard_Transient::DecrementRefCounter() const from ~/env/cmake/../lib/libTKernel.so.7+0x7
#2  0x7f479c380982 in netgen::OCCGeometry::~OCCGeometry() from ~/env/cmake/../lib/./libocc.so+0xe2
#3  0x7f47c07bb40e in NETGENPlugin_Mesher::Compute() from ~/env/cmake/../lib/libNETGENPlugin.so+0x3fe
#4  0x7f47c07c7934 in NETGENPlugin_NETGEN_2D::Compute(SMESH_Mesh&, TopoDS_Shape const&) from ~/env/cmake/../lib/libNETGENPlugin.so+0xa4
#5  0x7f47c05478c3 in SMESH_subMesh::ComputeStateEngine(SMESH_subMesh::compute_event) from ~/env/cmake/../lib/libSMESH.so+0x1173
#6  0x7f47c049a225 in SMESH_Gen::Compute(SMESH_Mesh&, TopoDS_Shape const&, int, MeshDimension, std::set<int, std::less<int>, std::allocator<int> >*) from ~/env/cmake/../lib/libSMESH.so+0x6d5
#7  0x7f47c0e8fac9 in MeshPart::Mesher::createMesh() const from ~/work/Mod/MeshPart/MeshPart.so+0x1279
#8  0x7f47c0e83281 in MeshPart::Module::meshFromShape(Py::Tuple const&, Py::Dict const&) from ~/work/Mod/MeshPart/MeshPart.so+0xe81
#9  0x7f47c0e7e95b in Py::ExtensionModule<MeshPart::Module>::invoke_method_keyword(void*, Py::Tuple const&, Py::Dict const&) from ~/work/Mod/MeshPart/MeshPart.so+0x2b
Before I dive into smesh, are there any critical occt7.2.0 changes we made to smesh. Maybe the 8.3 needs to see some updates too.
looo
Postby looo » Sat Mar 31, 2018 6:52 pm
I have two problems right now:
- StdMeshers_TrianglePreference.hxx is missing, so a workaround has to be found. (commenting out doesn't work)
https://github.com/looooo/FreeCAD/commi ... f55fd9R391
- the other problem is quite strange. It's reported some libs are missing if I use debug-builds of smesh and netgen:
Nicht definierter Verweis auf `SMESH_Mesh::AddHypothesis(TopoDS_Shape const&, int, std::string*)'
All works if I use release builds of netgen and smesh. No idea whats wrong here.
