porting to smesh 8.3
looo
Re: porting to smesh 8.3
Post by looo »
Thanks, so compiling smesh with libmed won't solve the issues I had with netgen and mefisto... But anyway I will try to convince pyocct to include libmed for the next release.
looo
Post by looo »
bernd wrote:related commits:
thanks for this hint. After inclusion of these commits, netgen and mefisto seem to work again.
I created a PR to get some feedback about the diff [1]. The remaining problem is the backward compatibility... But maybe someone else can have a look at this. Also I think it wouldn't be the worst idea to only support the externalized smesh...
[1] https://github.com/FreeCAD/FreeCAD/pull/1407
looo
Post by looo »
Finally it seems like the basic tests are working...
Bildschirmfoto vom 2018-04-25 11-13-49.png (23.76 KiB) Viewed 1266 times
ickby
Post by ickby »
that is awesome!
bernd
Post by bernd »
ickby wrote: Wed Apr 25, 2018 10:39 amthat is awesome!
:shock: :D
HoWil wrote:ping
Wilfried you will be very very happy ...
bernd
Post by bernd »
looo wrote: Sun Apr 15, 2018 8:34 pm
I wrote:Is libmed needed anywhere in FreeCAD or is it another dependency to make building FreeCAD more difficult?
does anybody know why we need the libmed library???
AFAIK to import and export med Mesh files. This was added from vejmarie. I do not know of someone else who ever talked about med file format.
bernd
HoWil
Post by HoWil »
looo wrote: Fri Mar 30, 2018 5:00 am but meshing a cube results in a crash
looo wrote: Wed Apr 25, 2018 9:18 am Finally it seems like the basic tests are working...
Nice! So are you now able to mesh a cube?
BR,
HoWil
looo
Post by looo »
yes, no crash anymore. This was related to a patch for netgen which was added for pyocct, but is not really necessary. I hope we can now share the sources/ dependencies with pyocct.
For netgen we still use a patch from the salome project:
https://github.com/conda-forge/netgen-f ... lome.patch
looo
Post by looo »
I post this here again:
the update to newer smesh8.3 breaks the unv import and gmsh-meshing tool (as it uses .unv import internally)
maybe this one will help?: https://github.com/FreeCAD/FreeCAD/comm ... 0d7cdd82f5
references:
https://forum.freecadweb.org/viewtopic. ... 80#p231430
looo
Post by looo »
the strange thing is that the unv file stores the mesh not in the order [1,2,3,4...10].
With the included smesh of FreeCAD:
1 7 3 6 2 5 8 10 9 4
(this order works)
with the external smesh 8.3:
1 3 2 4 7 6 5 8 10 9
which seems to be a wrong order
I wonder how the order is recrated in the working example. Is this done on SMESH side or on FreeCAD side?
