Is there a way to switch which side of a line the angle constraint is fixed upon? In this case, it's reading the obtuse angle, and I need it to read the acute angle:
I realize I can adjust it by subtracting the value from 180 degrees, but it's not really ideal.
Sketcher: Switch line side for angle constraint
- Joel_graff
Re: Sketcher: Switch line side for angle constraint
Just tried with 0.17, and you can create a construction line on the other acute side (with coincident constraints to keep it in place while your edit the rest of your sketch) and measure the angle from the construction line to your geometry line. Not super practical, but it works.
Cheers
Cheers
- Joel_graff
Hmmm... Seems like fodder for a feature request to me .dbecad wrote: ↑Tue Apr 10, 2018 4:16 pm Just tried with 0.17, and you can create a construction line on the other acute side (with coincident constraints to keep it in place while your edit the rest of your sketch) and measure the angle from the construction line to your geometry line. Not super practical, but it works.
Cheers
Still, interesting approach. I'll give it a shot. Thanks.
Is there a solution so far???
