Debugging python code.
keithsloan52
Postby keithsloan52 » Fri Apr 20, 2018 8:08 pm
Up until now, I have debugged python code by adding print statements to work out what is going on.
Is there something like a symbolic debugger that can be used with FreeCAD Python code?
ezzieyguywuf
Re: Debugging python code.
Postby ezzieyguywuf » Fri Apr 20, 2018 8:25 pm
pdb is helpful for this. Instead of using print statements, use import pdb; pdb.set_trace(). Now, the code will stop there and drop you into a prompt, where you can inspect variables and step through the code.
Postby Kunda1 » Fri Apr 20, 2018 9:26 pm
keithsloan52
Postby keithsloan52 » Sat Apr 21, 2018 7:11 pm
Tried this but it does not appear to invoke the debugger when it hits the pdb.set_trace(). Least does not open a debugging window as far as I can tell
OS: Mac OS X
Version: 0.17.13509 (Git)
Branch: tag: 0.17
Hash: 0258808ccb6ba3bd5ea9312f79cd023f1a8671b7
Python version: 2.7.14
Qt version: 5.10.1
OCC version: 7.2.0
Following @Kunda1 post the debugger needed changes to FreeCAD and I am wondering if these ever made it to FreeCAD 0.17
@mumme
Site Admin
Postby wmayer » Sat Apr 21, 2018 8:19 pm
pdb is very low-level debugger and doesn't offer any GUI. You more or less can compare it gdb to debug C/C++ code of gcc where you do everything from the command line.
If you want something high-level then using Winpdb might be an option. Just search for it in this forum.
keithsloan52
Postby keithsloan52 » Sat Apr 21, 2018 8:45 pm
Quite happy with the equivalent of a command line debugger like gdb but when I add
Nothing seems to happen when it reaches the pdb.set_trace.
I was expecting a window with a command line interface from what I read. Checked python console & report view but nothing.
winpdb does not seem to be an option. I don't have windows and my Linux machine died with a power supply failure.
So need something to work on the Mac
Site Admin
Postby wmayer » Sat Apr 21, 2018 8:52 pm
Winpdb itself is written in Python and all what it needs is wxWidgets and its Python binding. This should also be available on macOS.
keithsloan52
Postby keithsloan52 » Sat Apr 21, 2018 9:23 pm
Okay as per http://macappstore.org/wxmac/
I ran
brew install wxmac
and was told wxmac 3.0.4 is already installed and up-to-date
To reinstall 3.0.4, run `brew reinstall wxmac`
I assume I have to download a source version of winpdb and somehow link it into python.
Not sure how to do the later.
keithsloan52
Postby keithsloan52 » Sat Apr 21, 2018 9:29 pm
Okay I guess I just download the source and run the install script as per Linux.
I will give it a try.
keithsloan52
Postby keithsloan52 » Sun Apr 22, 2018 5:21 pm
Okay I have winpdb installed.
I tried to follow https://www.freecadweb.org/wiki/Debuggi ... _Debugging
and created a test.py file as
import rpdb2
rpdb2.start_embedded_debugger("test")
import FreeCAD
open("/Users/keith/Desktop/Problem/test2.csg")
After I load it into FreeCAD and press f6
I get an error
import rpdb2
ImportError: No module named rpdb2
I assume that I have to copy something to do with rpdb2 to somewhere in FreeCAD
