Hello all,
Freecad version:
OS: Windows 7
Version: 0.17.13509 (Git)
Branch: releases/FreeCAD-0-17
Hash: 0258808ccb6ba3bd5ea9312f79cd023f1a8671b7
Python version: 2.7.14
OCC version: 7.2.0
Locale: Dutch/Belgium (nl_BE)
Issue:
I have a file made during with regular updated 0.17 development versions of freedcad.
Since the 0.17 release freecad crashes when I switch workbench for instance from arch to techdraw. Or from techdraw to drawing dimensions. And also from drawing to drawing dimension. Other switching I have not tried.
I removed the local MOD and Macro files out of the way. Behavior is the same.
I tried the 0.18 development version and has the same behavior.
What can I do to help debuging this issue.
Johnny
Freecad crash when switching workbench
Re: Freecad crash when switching workbench
Even if it doesn't help here: you should use version 0.17.13515.
this may be relevantJohnny Geling wrote: ↑Mon Apr 23, 2018 8:24 pm Hello all,
Issue:
Johnny
https://forum.freecadweb.org/viewtopic.php?f=4&t=28236
https://forum.freecadweb.org/viewtopic. ... 36#p228961
Please note that I think you wouldn't need to check "add to python path" option to solve this issue.
I have also on my work PC some trouble with same behaviour. Only in my case switching to Part or Part Design.
But till know in my case it is possible that it is partly related that i run other CAD software at the same time with not a real big amount of memory...
Also Windows 7 and around same version number...
(Solved) Re: Freecad crash when switching workbench
Following the suggestions in the link from easyw-fc I'm able to solve the issue and re-create the issue.
I moved my user.cfg and system.cfg from the AppData\Roaming\FreeCAD folder.
With a new config files freecad doesn't crash. Even with the latest released 0.17 version.
Putting the old config files back and freecad crashes switching the workbench.
Is there an easy way to compare the config files and find the root cause?
Apparently I'm to quickly with my conclusion. After re-creating the issue with the old config files, freecad also crashes with new, fresh config files.
Johnny
Johnny
Can you start freecad from a cmd promptJohnny Geling wrote: ↑Tue Apr 24, 2018 7:07 pm Apparently I'm to quickly with my conclusion. After re-creating the issue with the old config files, freecad also crashes with new, fresh config files.
freecad -l
"fight the good fight"
