[SOLVED]: Sketcher cannot select points
easyw-fc
Postby easyw-fc » Fri Jun 01, 2018 10:36 am
in the attached file I cannot select points to add a constraint.
It is also not possible to add a constraint even when selecting the points with a different method from simple click,
sk1.FCStd
(3.49 KiB) Downloaded 13 times
Version: 0.18.13870 (Git)
Hash: f0964a9c052ee666631cd9caec1655790964ecb6
Python version: 2.7.14
OCC version: 7.2.0
This was possible until
Version: 0.18.13830 (Git)
Hash: 262d7c0cd05c6072d5807ebb98a0a3113cfebba0
OCC version: 7.2.0
Re: Bug: Sketcher cannot select points
Postby chrisb » Fri Jun 01, 2018 4:16 pm
No problem here. Did you try to close and reopen the file? Or restart FreeCAD?
OS: Mac OS X
Version: 0.18.13826 (Git)
Branch: (HEAD detached at 3b02ff2)
Hash: 3b02ff2a9481f0883063c7e24c312978ef0ce642
Python version: 2.7.15
Qt version: 5.11.0
OCC version: 7.2.0
easyw-fc
Postby easyw-fc » Fri Jun 01, 2018 4:55 pm
OS: Mac OS X
but have you read my post?
I have this issue with Version: 0.18.13870 (Git)
and not until
Version: 0.18.13830 (Git) included
you are on Version: 0.18.13826 (Git) which is before the still good one
GeneFC
Postby GeneFC » Fri Jun 01, 2018 6:58 pm
I can verify on Windows 7.
Works correctly in 0.18.13824.
Fails in 0.18.13870.
Gene
Postby chrisb » Fri Jun 01, 2018 7:56 pm
and not until
Sorry, I missed the line above the second FreeCAD info and had thought it doesn't work on these two versions :oops: .
Site Admin
Postby wmayer » Sat Jun 02, 2018 9:12 am
I guess it's a regression caused by this PR https://github.com/FreeCAD/FreeCAD/pull/1483/files
DeepSOIC
Postby DeepSOIC » Sat Jun 02, 2018 11:43 am
No problem here:
OCC version: 7.2.0
Locale: Russian/RussianFederation (ru_RU)
WTF?
DeepSOIC
Postby DeepSOIC » Sat Jun 02, 2018 11:46 am
OK, I see WTF. If I turn the grid on, I have the same problem.
The points ARE being selected (I can see it in selection view), but the selection does not render. It is affected by grid being rendered somehow.
For example, I have no grid, and select a point. So far so good. Now I switch the grid on, and the point becomes red. And I toggle the grid back off and the point is green again.
Site Admin
Postby wmayer » Sat Jun 02, 2018 2:26 pm
And it looks like that only points that have a coincidence applied are affected because selection works correctly for the start or end points of a polyline. And when selecting the inner points via box selection then the rendering is OK because then both points are selected.
So, it must have something to do with the z values used for the rendering.
abdullah
Postby abdullah » Sat Jun 02, 2018 2:50 pm
Somehow, grid rendering affects points at a height lower than zHighlight. The algorithm was setting the zheight of the points regardless of whether the where selected/preselected.
This should fix it:
https://github.com/FreeCAD/FreeCAD/pull/1490
