fun with occt 7.3 defeaturing
- tanderson69
A new operation was introduced in occt 7.3 called defeaturing. It works by removing faces from a solid and then trying to close the hole by extending the faces that remain. I took some time and ran some basic tests. Referencing the picture below: The left picture shows the input solid and the white faces to remove. The right picture shows the result of the defeaturing operation. Everything worked great with the exception of test 3. Which is surprising, as test 3 is a simpler case of test 7, which worked. I tried modeling test 3 a couple different ways, but could not get it to work. Anyway it is a great addition to occt modeling.
Re: fun with occt 7.3 defeaturing
Nice for FEM removing holes, not working radii etc
- DeepSOIC
Cool feature
Nice to see this feature.
In Solid Edge (Parasolid-based) there is a similar utility and I find it extremely useful.
It would be really great if some FreeCAD developer were to add GUI tools in FreeCAD to use this new OCCT feature. One who already experimented with it. Hint, hint.
Would the Reverse Engineering workbench be a good place for such a utility?
something like this ... https://forum.freecadweb.org/viewtopic. ... 98#p238398 If that would work it would be as good as all the CompSolid stuff we got with occt 6.9 and DeepSoics BooleanFragments in FreeCAD
- tanderson69
That solid fails the normal check geometry(not bopcheck). I would call that 'corrupt' and I would guess most modeling algorithms will fail with that as input. IMHO: a manual fix is the only solution. Extract faces, fill voids with new faces and a sew operation. Something as simple as that, I would just start from scratch using the imported geometry as only a guide.bernd wrote: ↑Sun Jun 10, 2018 3:59 am something like this ... https://forum.freecadweb.org/viewtopic. ... 98#p238398 If that would work ...
- kkremitzki
OCCT 7.3 is now in the Debian NEW queue waiting for the upgrade to be approved, by the way.
- tanderson69
thank you.kkremitzki wrote: ↑Sun Jun 10, 2018 2:28 pm OCCT 7.3 is now in the Debian NEW queue waiting for the upgrade to be approved, by the way.
