this is an idea which following me around for long time. Keyboard manipulator 3D based on idea of 3d connexion spacemouse. This is ergonomic utility which fasten desingning process. Unfortunatelly my programming skills are poor (still increasing in python, but I found recently that this cannot be realized by python at least I don't know how), so I am looking for developer who would be interested and be able to pull this project.
The idea is to do all manipulator things with keyboard with fast access (doble space for example). I found in my opinion optimal configuration of keys, which are easy access and all operations (roatations/zooming at the same time) should be possible to do without bigger problem and using only one hand.
My idea of keys preset (can be configurable):
Looking for your comments
Presentation of 3d space mouse: https://youtu.be/C9lIYmkYrXk?t=2m
Re: Keyboard manipulator 3D
LOL. Are you a PC FPS player by any chance?
Hi @efyx
Just looking at the image (good job on providing one) your suggestion doesn't stand a real chance (defaults). Your proposal is occupying one third of the keyboard. All sort of local/global shortcuts already occupy that by default. Therefore if somebody would create a feature like you suggest. It likely would require for the end user to customizes the shortcut keys to a scheme as you suggest. As for the feature itself. If somebody is prepared to code it. Sure, why not.
hi efix
here to start with many link for the camera documentation other in my signature (extract of my Macro_Mouse_Cross)
mario
# -*- coding: utf-8 -*-
#################### create document if not exist #######################
doc = FreeCAD.ActiveDocument ####
if doc == None: ####
doc = FreeCAD.newDocument() ####
class ViewObserver:
def logPosition(self, info):
print info
print "_______________________"
self.pos = info["Key"]
if (self.pos.upper() == "Q"): # quit and close the ViewObserver() (or choice other key)
v.removeEventCallback("SoKeyboardEvent",c)
print "End Macro_Mouse_Cross"
if (self.pos.upper() == "S"):
print cam
print "S"
elif (self.pos.upper() == "F"):
print "F"
elif (self.pos.upper() == "E"):
print "E"
elif (self.pos.upper() == "D"):
print "D"
elif (self.pos.upper() == "Z"):
print "Z"
elif (self.pos.upper() == "V"):
print "V"
elif (self.pos.upper() == "W"):
print "W"
elif (self.pos.upper() == "R"):
print "R"
# elif (self.pos.upper() == "Q"):
# print "Q"
elif (self.pos.upper() == "T"):
print "T"
elif (self.pos.upper() == "A"):
print "A"
try:
v=Gui.activeDocument().activeView()
o = ViewObserver()
c = v.addEventCallback("SoKeyboardEvent",o.logPosition)
App.Console.PrintMessage("Type Key Q to Quit"+"\n")
except Exception:
FreeCAD.Console.PrintError("\n"+"Not document open"+"\n")
## documentation Camera
## http://web.mit.edu/ivlib/www/iv/cameras.html
## http://forum.freecadweb.org/viewtopic.php?f=22&t=5576#p45446
## http://forum.freecadweb.org/viewtopic.php?f=10&t=2552&p=18998&hilit=setCamera#p18998
## http://forum.freecadweb.org/viewtopic.php?f=8&t=3520&p=27474&hilit=setCameraOrientation#p27474
## https://grey.colorado.edu/coin3d/classSoOrthographicCamera.html
## http://forum.freecadweb.org/viewtopic.php?f=22&t=6745
## http://forum.freecadweb.org/viewtopic.php?f=22&t=10157
## http://forum.freecadweb.org/viewtopic.php?f=22&t=11734
## http://forum.freecadweb.org/viewtopic.php?f=8&t=10573&start=80
## https://www.forum.freecadweb.org/viewtopic.php?f=22&t=22850
## http://forum.freecadweb.org/viewtopic.php?f=3&t=7029&p=56735&hilit=setCameraOrientation#p56735
## http://forum.freecadweb.org/viewtopic.php?f=13&t=14213
## https://www.forum.freecadweb.org/viewtopic.php?f=22&t=26391
## http://developer90.openinventor.com/content/42-cameras
## https://www.forum.freecadweb.org/viewtopic.php?f=22&t=26500
# PerspectiveCamera. A PerspectiveCamera shows you the scene and applies foreshortening to give you a better impression of distance.
# PerspectiveCamera {
# viewportMapping ADJUST_CAMERA
# position 0 0 1
# orientation 0 0 1 0
# aspectRatio 1
# nearDistance 1
# farDistance 10
# focalDistance 5
# heightAngle 0.785398
# OrthographicCamera. A OrthographicCamera shows you the scene but doesn't apply any foreshortening.
# OrthographicCamera {
# position 0 0 1
# aspectRatio 1
# nearDistance 1
# farDistance 10
# focalDistance 5
# height 2
#Gui.activeDocument().activeView().setCamera('#Inventor V2.1 ascii \n OrthographicCamera { \n viewportMapping ADJUST_CAMERA \n position 0 0 87 \n orientation 0 0 1 0 \n nearDistance 37 \n farDistance 137 \n aspectRatio 1 \n focalDistance 87 \n height 119 }')
Man I loved TF2. I may have played more hours than you, back in the day... (I haven't logged in to my Steam account in years)
Heavy wrote:I love this doctor!
Soldier wrote:MEDIC!!!!
Nope, but always wanted to
Thanks for meritoric voice
This is really cool, I'll look at it. Thanks.
Looks like it is designed, right for your needs
