Stuck on Copying DocumentObject or ComplexGeoData
wandererfan
Post by wandererfan »
I'm working on this: issue #3329 (Object placement in exported Stl). I fixed a similar situation in TechDraw by making copies of TopoShapes, applying globalPosition(), and exporting the copies.
But I'm having trouble getting something I can modify. I need to make a copy of the DocumentObject or the ComplexGeoData, but I get "use of deleted function" (no explicit copy constructor?).
bool MergeExporter::addPartFeat(App::DocumentObject *obj, float tol)
    auto *shape(obj->getPropertyByName("Shape"));
//    App::DocumentObject objCopy(*obj);         <<< these would be good
//    App::DocumentObject* objCopy = obj->Copy(); <<<
    if (shape && shape->getTypeId().isDerivedFrom(App::PropertyComplexGeoData::getClassTypeId())) {
        Base::Reference<MeshObject> mesh(new MeshObject());
        auto countFacets( mergingMesh.countFacets() );
       //  geoData is const :(
        auto geoData( static_cast<App::PropertyComplexGeoData*>(shape)->getComplexData() );
//        auto gd2(geoData->Copy());                  <<<  want something like this ( !const)
        if (geoData) {
            App::GeoFeature* gf = static_cast<App::GeoFeature*>(obj);
            // setPlacement breaks const :(   -  but I shouldn't modify the original anyway
//            geoData->setPlacement(gf->globalPlacement());
            std::vector<Base::Vector3d> aPoints;
            std::vector<Data::ComplexGeoData::Facet> aTopo;
            geoData->getFaces(aPoints, aTopo, tol);
I could make this work by using Part::Feature and/or Part::TopoShape, but that would make Mesh module need the *h file(s) from Part and the OCC include lib, and I'm guessing that would be discouraged(?).
Any advice?
