Enhancement - dimensions
efyx
Postby efyx » Wed Jul 25, 2018 7:30 am
I really like in SW, when first you prepare sketch and then extrude for example, that you can select sketch in 3d model view and all dimensions from sketch appear and you can select it and change without insering into sketch mode. Is it possible to add such functionality? Pic below.
dimensions enhancement.png (75.92 KiB) Viewed 360 times
The same is with further operations when you click for example extrude, all dimensions under this operation appears:
dimensions enhancement 2.png (54.05 KiB) Viewed 355 times
Re: Enhancement - dimensions
Postby chrisb » Wed Jul 25, 2018 2:22 pm
We have the direct editing mode with the possibility of changing properties in the Property tab; alas we don't have the visualisation of the measures without entering the edit mode.
efyx
Postby efyx » Wed Jul 25, 2018 6:57 pm
Good you've mention it. You are right! Too many habits from SW (10 years do work).
efyx
Postby efyx » Thu Jul 26, 2018 7:22 am
Edit: uh that is available only for primitives, no sketch or pad (or am I wrong)?
Postby chrisb » Thu Jul 26, 2018 10:54 am
For the Pad you have the Length attribute.
For sketches you have an unforlable attribut Constraints, easy to distinguish if the constraint in question has a name, otherwise you have to guess by the value. The latter is another good reason for having simple sketches.
