the occt shape sharing works great as long as all the shapes are wrote to the same brep file. Think... 'aggregate TopoDS_Compound'. I tested and proved this out about 5 years ago. Juergen didn't seem very interested, when I brought it up. I am doing it successfully in another project, so believe me it works.
Shape sharing and save-restore
- tanderson69
Re: Merging of my Link branch
- DeepSOIC
this is getting off-topic, but...
I create Lattice2 Polar array, and run to test if there is sharing:
After array creation/recompute:
and after save/load:
Version: 0.18.13935 (Git)
Hash: cb133767464337e4b5c8589a1fe33b4d7dad7721
Python version: 2.7.14
OCC version: 7.2.0
Locale: Russian/RussianFederation (ru_RU)
I'm afraid I can't reproduce it.tanderson69 wrote: ↑Fri Aug 03, 2018 1:07 pm the occt shape sharing works great as long as all the shapes are wrote to the same brep file. Think... 'aggregate TopoDS_Compound'. I tested and proved this out about 5 years ago. Juergen didn't seem very interested, when I brought it up. I am doing it successfully in another project, so believe me it works.
sh = App.ActiveDocument.PolarArray.Shape
sh.Shells[0].isPartner(sh.Shells[1]) # shells are paper planes, should be a one shell used many times...
True
False
OCC version: 7.2.0
- DeepSOIC
tanderson69 wrote: ↑Fri Aug 03, 2018 1:07 pm I am doing it successfully in another project, so believe me it works.
Any ideas on what the difference might be? I've glanced through the source you sent me in PM, and I don't straight see anything special. Does it write a binary brep, or an ascii one?
- tanderson69
Re: Shape sharing and save-restore
No. I was thinking about doing some more experiments, but haven't fit it in yet.
Those are ascii. you have to get into the occt bintools for binary.https://dev.opencascade.org/doc/refman/ ... tools.html
I moved some topics here on request of DeepSOIC. Please verify it were the right ones.
This is because PropertyTopoShape performs a copy before saving, which seems to be a deep copy and destroys the shape sharing. I have just submitted a PR for this. See the description for details.DeepSOIC wrote: ↑Fri Aug 03, 2018 2:23 pm this is getting off-topic, but...
It is indeed like what tanderson69 said, the maximum efficiency can be achieved by storing all shapes inside one file. But then, the same thing can be achieved, to some extent, if my Link gets wildly used , which BTW, your Lattice seems a perfect use case.
Storing all shapes into one file has an disadvantage, though. My branch now supports partial document loading when externally linked, meaning only the referenced shapes gets loaded. Storing all shapes in one file kind of defeats its purpose.
- DeepSOIC
Oh, nice!!realthunder wrote: ↑Sat Aug 04, 2018 6:39 am This is because PropertyTopoShape performs a copy before saving, which seems to be a deep copy and destroys the shape sharing. I have just submitted a PR for this. See the description for details.
- tanderson69
In regards to the pull request: The link you posted is for writing binary tools. Doesn't FreeCAD saves in the ascii format? Seems like 'BRepTools::Write' saves the triangulation. It looks like at one time the original shape was getting cleaned and that was leading to problems. So a copy was added. By the way, I think the call to BRepTools::Clean now is redundant. BRepBuilderAPI_Copy will only copy the triangulation with the appropriate parameter. https://dev.opencascade.org/doc/refman/ ... _copy.htmlrealthunder wrote: ↑Sat Aug 04, 2018 6:39 amThis is because PropertyTopoShape performs a copy before saving, which seems to be a deep copy and destroys the shape sharing. I have just submitted a PR
I have had the same thought, but then I think if I can share all that data across features and components why would I need to partial load the brep. I think the sharing is one occt greatest strengths, if they can track down all the bugs it causes.realthunder wrote: ↑Sat Aug 04, 2018 6:39 am Storing all shapes into one file has an disadvantage, though. My branch now supports partial document loading when externally linked, meaning only the referenced shapes gets loaded. Storing all shapes in one file kind of defeats its purpose.
I have been pondering partial loading for a while. I have designed some pretty descent sized assemblies with less than 1 gig of ram, so I appreciate what it can do for you. I just feel that with every passing year, partial loading gets less and less important. I know! dangerous/lazy thinking. There will always be assemblies that won't fit into memory.
- tanderson69
Did an experiment this morning. If you look at the code for 'BRepTools::Write' it isn't really doing anything other using BRepTools::ShapeSet https://git.dev.opencascade.org/gitweb/ ... =HEAD#l689 BRepTools::ShapeSet has a parameter for storing with triangles. So I created a quick test that writes out 2 files directly using BRepTools::ShapeSet. If you diff the results, it looks like this will work. This way we won't have to 'clean' the shapes before write. Should save the sharing and also be a little faster. The more time I spend thinking about this, I feel the shapes should just be all wrote out in binary. Especially if all the shapes will be saved into a giant compound. Why are we saving in ascii?
#include <iostream>
#include <sstream>
#include <string>
#include <vector>
#include <stdexcept>
#include <fstream>
#include <BRepPrimAPI_MakeBox.hxx>
#include <BRepMesh_IncrementalMesh.hxx>
#include <TopoDS_Solid.hxx>
#include <BRepTools.hxx>
#include <BRepTools_ShapeSet.hxx>
int main (int /*argc*/, char** /*argv*/)
try
TopoDS_Solid box = BRepPrimAPI_MakeBox(gp_Pnt(0.0, 0.0, 0.0), gp_Pnt(10.0, 10.0, 10.0)).Solid();
BRepMesh_IncrementalMesh(box, 0.25);
std::ofstream withStream("./withTriangles.brep", std::ios_base::out | std::ios_base::trunc);
BRepTools_ShapeSet withSet(Standard_True); //this is the default
withSet.Add(box);
withSet.Write(withStream);
withSet.Write(box, withStream);
std::ofstream withOutStream("./withOutTriangles.brep", std::ios_base::out | std::ios_base::trunc);
BRepTools_ShapeSet withOutSet(Standard_False);
withOutSet.Add(box);
withOutSet.Write(withOutStream);
withOutSet.Write(box, withOutStream);
std::cout << std::endl << "Program finished normally" << std::endl;
catch (const Standard_Failure &error)
std::cout << "OCC Error: " << error.GetMessageString() << std::endl;
catch (const std::exception &error)
std::cout << "My Error: " << error.what() << std::endl;
return 0;
- withTriangles.brep
- (3.67 KiB) Downloaded 32 times
- withOutTriangles.brep
- (2.49 KiB) Downloaded 41 times
