Both already available from:
https://github.com/FreeCAD/FreeCAD/releases/tag/0.18.1
https://github.com/FreeCAD/FreeCAD/rele ... g/0.19_pre
I noticed this as well, don't know what caused it to change?
Until now it only crashed on language change.triplus wrote: ↑Fri May 10, 2019 9:29 pmOK, therefore it's likely safe to assume Qt 5.6.2 Conda package, by itself, isn't the main problem here. I made a small change and first i guess @chrisb should test if the latest FreeCAD 0.18/0.19 .dmg from releases page still crash as often on his side or not, after we can discuss this further.
No such crash here
OS: Ubuntu 16.04.6 LTS (Unity/ubuntu)
Version: 0.19.16694 (Git) AppImage
Hash: cd74f2e92908e94f9f7bc718e1be52939647b844
Python version: 3.7.1
Qt version: 5.6.2
As I said, it's not reproducible here either.
It is so far stable but I have admittedly not exercised it much (using 18.1 for regular work). I had just downloaded the cited 0.19 version when I saw your post so I thought I'd test it. I just offered the result as another data point.chrisb wrote: ↑Sun May 12, 2019 11:55 amAs I said, it's not reproducible here either.
It would be very interesting to know, if you have other crashes or if your setup runs stable.
Things became bad here this morning: I had here this approximately 3 crashes per hour, while modeling, following the forum, and reproducing issues.
It's not that special 0.19 version, I have the issues with 0.18 as well. I understand that 0.18.1 is stable at yours.
