FreeCAD flatpak
Re: FreeCAD flatpak
Sorry, I hit that too (local vs build server) but copied glu from an earlier manifest. I'll paste it here once I can paste (seems to be a Firefox bug).
Re: FreeCAD flatpak
modules:
# - shared-modules/glu/glu-9.0.0.json # TODO: remove with next runtime
- name: glu
cleanup:
- /include
- /lib/*.a
- /lib/*.la
- /lib/pkgconfig
sources:
- type: archive
url: https://mesa.freedesktop.org/archive/glu/glu-9.0.0.tar.bz2
sha512: ff920e3fbca739794e1432a92fdd8517aa732110fea71ed724185425042f83ce18e9866c16f95c6e10f6993f0814a90fac9636e2b3d8ca2084d1ac0a860f61c8
https://github.com/flathub/shared-modul ... 9.0.0.json
converted to .yaml. Fixed in the earlier instructions.
Re: FreeCAD flatpak
Thanks, a step forward I have a "wrong" set of patches:
fedora:/home/przemo/software/freecad-flatpak
$ grep patches org.freecadweb.FreeCAD.yaml
path: patches/coin3d-fixed-wrong-assignment.patch
path: patches/coin3d-gcc6-crash-fix.patch
path: patches/opencascade-vtk.patch
# path: patches/freecad-qt5.11.patch
$ ls -1 patches
coin3d-3.1.3-gcc-4.7.patch
coin3d-3.1.3-gcc-4.8.patch
shiboken-1.2.4-fix-collector_external_operator_test.patch
shiboken-1.2.4-python3.patch
shiboken-1.2.4-simplefile-test.patch
Re: FreeCAD flatpak
I had to start from scratch with Peter's patches. I downloaded them manually from here (there are 4 but I only use 3):
https://github.com/flathub/flathub/pull ... df60d8fb08
Re: FreeCAD flatpak
Perfect, thanks!
$ cat get_patches.sh
wget -P patches https://raw.githubusercontent.com/flathub/flathub/e034fab015a8921eeb6afd5e21f9b1df60d8fb08/patches/coin3d-fixed-wrong-assignment.patch
wget -P patches https://raw.githubusercontent.com/flathub/flathub/e034fab015a8921eeb6afd5e21f9b1df60d8fb08/patches/coin3d-gcc6-crash-fix.patch
wget -P patches https://raw.githubusercontent.com/flathub/flathub/e034fab015a8921eeb6afd5e21f9b1df60d8fb08/patches/freecad-qt5.11.patch
wget -P patches https://raw.githubusercontent.com/flathub/flathub/e034fab015a8921eeb6afd5e21f9b1df60d8fb08/patches/opencascade-vtk.patch
Re: FreeCAD flatpak
Peter Eszlari suggested the KDE flatpak repository for nightly builds, and linked this on the PR.
https://community.kde.org/Guidelines_and_HOWTOs/Flatpak
Here is last year's announcement of the Firefox Nightly:
https://eischmann.wordpress.com/2017/02 ... r-flatpak/
Re: FreeCAD flatpak
Peter's package was accepted on Flathub:
https://flathub.org/apps/details/org.freecadweb.FreeCAD
Here's the repository:
https://github.com/flathub/org.freecadweb.FreeCAD
Re: FreeCAD flatpak
Great! I think we need to fix the release number broken by shallow git clone. I had the same problem with COPR.
FreeCAD 0.17, Libs: 0.17R5235 (Git shallow)
My solution for COPR is:
function git_commits_no {
commits=$(git fetch --unshallow && git rev-list master --count)
echo $commits
Re: FreeCAD flatpak
Great... do you want to add it as an issue?
Re: FreeCAD flatpak
I feel like I should have a ready solution instead of opening an issue, but I've done it anyway
