LinkStage3 branch and TechDraw Module Test Results
wandererfan
Postby wandererfan » Sat Aug 18, 2018 2:08 pm
I'm not happy to be writing this, but LinkStage3 seems to have significant issues, at least as far as TechDraw (and presumably other built-ins, add-ons and macros) goes. Merging into master at this time does not seem appropriate.
I used "FreeCAD-asm3-20180811-aee619a0-a2a5d69.glibc2.17-x86_64.AppImage" for this testing. I did not use asm3 python functionality directly.
OS: Linux Mint 18.3 Sylvia
Version: 0.17.5235 (Git shallow) AppImage
Build type: None
Branch: LinkStage3
Hash: ccaa87e12aaadbd3106607fc503542a863b742da
Python version: 2.7.6
Qt version: 4.8.6
Results are based on test files asm3Test.fcstd and Basic_TechDraw_Tutorial.fcstd (attached)
TechDraw handling of LinkStage3 constructs in "asm3Test.fcstd":
The top two levels of the assembly cannot be printed by TechDraw. They are "Part::Features", so TD expects to find a Shape property which it can draw. Assembly and Parts objects claim to be Part::Features, but their Shape property is Null.
TechDraw will recursively hunt for Shapes to draw by tranversing the children of App::GroupExtension objects. Assembly and Parts have a Group property, but don't appear to be GroupExtensions. Neither LS3 object has methods "hasExtension", "isDerivedFrom" or "getTypeId" methods, so it is difficult to be sure.
The "Angle" object is a "PartDesign::Body" and is printed correctly.
LS3 impact on TD function using "Basic_TechDraw_Tutorial.fcstd"
On loading Basic_TechDraw_Tutorial into LS3, I received a string of messages in the form:
<PropShape> PropertyTopoShape.cpp(316): auto generate element map: Body
<PropShape> PropertyTopoShape.cpp(316): auto generate element map: Sketch
<PropShape> PropertyTopoShape.cpp(316): auto generate element map: Pad
Selection is broken in TD under LS3. Items highlight in QGraphicsView and Tree correctly, but appears that subobjects (edges, vertices, faces) are no longer returned by getSelectionEx().
This behaviour is also found in Python macros using getSelectionEx.
The selection issue also has some impact on the 3D window. After encountering selection issues on the TD Page, I was unable to select edges or vertices in the 3D window.
At various points while using Selection, I received the following messages:
Unhandled Base::Exception caught in GUIApplication::notify.
The error message is: Shape index out of bound
This message seems to accompany damage to pieces of the 3D model with objects being marked as "inError" in the Tree.
At one point, while attempting to apply Dimensions to an edge, I received these message:
Updating geometry: Error build geometry(1): Both points are equal
Invalid solution from DogLeg solver.
At this point the tutorial object morphed into a different shape;
Original Shape:
Morphed Shape:
No amount of recomputing would bring back the original tutorial shape.
Save/Reload resulted in these messages and the same(?) deformed object.:
Reading failed from embedded file: PartShape16.brp (35853 bytes, 5948 bytes compressed)
Rebuilding Views for: Page/Page
<App::Document> Document.cpp(2276): 'deformedBTDTutorial' failed to restore object 'Dimension002': Shape index out of bound
Rebuilding Views for: Page001/Page001
Lines are parallel
Lines are parallel
<type 'exceptions.IOError'>: Shape index out of bound
At this point, disillusionment set in and I stopped my testing.
wf
Other messages received during testing:
I also received a number of messages that I did not investigate further:
Coin error in SoEventManager::processEvent(): Recursive invocation detected. Delay processing event until the current event is finished processing. (32 repeats)
- can't use 3d window after this. just starts repeating as soon as cursor enters 3D window.
With Assembly selected and Visibility changed (via spacebar):
<asm3.main> 393.798875 - mover.py(291): exception when moving part
File "/tmp/.mount_FreeCADy7CMh/usr/lib/freecad-daily/Ext/freecad/asm3/FCADLogger.py", line 83, in _catch
return func(*args,**kargs)
File "/tmp/.mount_FreeCADy7CMh/usr/lib/freecad-daily/Ext/freecad/asm3/mover.py", line 243, in getMovingElementInfo
raise RuntimeError('no sub-object in selection')
RuntimeError: no sub-object in selection
<asm3.main> 264.373876 - mover.py(291): exception when moving part
File "/tmp/.mount_FreeCAGZmwfM/usr/lib/freecad-daily/Ext/freecad/asm3/FCADLogger.py", line 83, in _catch
File "/tmp/.mount_FreeCAGZmwfM/usr/lib/freecad-daily/Ext/freecad/asm3/mover.py", line 243, in getMovingElementInfo
During initialization the error No module named matplotlib occurred in /home/huxster/.FreeCAD/Mod/animation/InitGui.py
Please look into the log file for further information
(69.96 KiB) Downloaded 13 times
asm3Test.fcstd
(73.35 KiB) Downloaded 13 times
realthunder
Re: LinkStage3 branch and TechDraw Module Test Results
Postby realthunder » Sun Aug 19, 2018 4:05 am
Thanks for the lengthy report.
This is by design, for quick assembly solver recomputation. The user can control at which level to generate the shape, by `BuildShape` property in the assembly container. Set it to compound and TechDraw will be happy.
Assembly does not use GroupExtension. There is a more powerful utility function Part::Feature::getTopoShape() to retrieve the shape from any object, include group, link, and of course the assembly container. I didn't modify TechDraw WB to use it because I am not that familiar with this WB yet.
My branch include a new feature called Topological Naming. For testing purpose, the default setting is to auto generate new topological names for legacy model. You can turn this off by create and set the parameter 'BaseApp/Preferences/Mod/Part/General/AutoElemenetMap' to false, and restart FC.
This is a bug, and has been fixed already. Please try the latest release
The error is exposed by the whole document recomputation for generating the new topological names. However, the new topo name is not the cause of the problem. It is in fact a defect (or compatibility issue) of OCCT 7.3. This problem does not occur for OCCT 7.1. I didn't try 7.2. You can verify this by open the file in upstream 0.18 AppImage, mark the document for recomputation, and recompute it. You'll get the same broken shape. This is in fact a dangerous bug, potentially breaking legacy models with no obvious reason. I'll investigate it further.
I suspect the many of the following errors are caused by the broken shape.
Can't think of the cause of this. But I do experience this behavior occasionally in the past. It is usually triggered by some unexpected exception (e.g. Unhandled Base::Exception caught in GUIApplication::notify) during coin nodes traversal.
I am not sure how you trigger this problem. I do fix the double clicking behavior of assembly container, which produce similar error. Please try again with the new version.
'animation' is a third party workbench. ASAFIK, AppImage can't use your system's python package, and matplotlib is not bundled within.
wandererfan
Postby wandererfan » Mon Aug 20, 2018 12:00 am
Using Part::Feature::getTopoShape makes things a lot better:
Still some sort of problem with the Dimension object. In the tree it is labelled "Unnamed" but in the property editor it is labelled "Dimension" as it should be.
I couldn't figure out how to make a pull request against your repo, so here is the change in .../TechDraw/App/DrawViewPart.cpp:
std::vector<TopoDS_Shape> DrawViewPart::getShapesFromObject(App::DocumentObject* docObj) const
    std::vector<TopoDS_Shape> result;
    App::GroupExtension* gex = dynamic_cast<App::GroupExtension*>(docObj);
    if (docObj->getTypeId().isDerivedFrom(Part::Feature::getClassTypeId())) {
        Part::Feature* pf = static_cast<Part::Feature*>(docObj);
        Part::TopoShape ts = Part::Feature::getTopoShape(pf);
        if (!ts.isNull()) {
            ts.setPlacement(pf->globalPlacement());
            result.push_back(ts.getShape());
fosselius
Postby fosselius » Mon Aug 20, 2018 4:34 am
I can create the pull request if realthunder have not yet added your fix.
Here is a guide on how to create pull requests: https://help.github.com/articles/creati ... l-request/
Basically, you go to https://github.com/realthunder/FreeCAD press "fork", you will get a copy of realthunders repo in your namespace, then you check it out, make changes, commit, push, then in the github interface on your copy of the project you press "make pull request", select branches etc.
realthunder
Postby realthunder » Mon Aug 20, 2018 4:38 am
Thanks for trying. I will modify your patch a bit before applying, to support objects other that Part::Feature.
wandererfan
Postby wandererfan » Mon Aug 20, 2018 12:21 pm
Thanks, that was the first thing I tried, but apparently having 2 forks of the same repo (FreeCAD/FreeCAD) in 1 Github account is frowned upon. I also tried the work around of creating an empty repo on github and pushing from my local repo. That made the repo, but I couldn't get the Base and Head values correct when trying to make a PR.
Will have to sort that out if I find myself contributing on a more regular basis.
triplus
Postby triplus » Mon Aug 20, 2018 9:33 pm
Matplotlib is added to the AppImage but it isn't being used.
https://github.com/AppImage/AppImages/pull/339
realthunder
Postby realthunder » Tue Aug 21, 2018 1:28 pm
Thanks, I'll update the recipe in next release.
Hi wandererfan, I have just update LinkStage3, and its lastest commit is to add Link and SubObject support to TechDraw. Please check. I have relaxed selection object type requirement to TechDraw, and rely on Part::Feature::getShape() to obtain shape and sub-shape. With Link, one can now put the drawing in a separate file, and use Link to externally link to the geometry model. And SubObject support allows one to link to a geometry element of a child object in an external group.
wandererfan
Postby wandererfan » Tue Aug 21, 2018 11:19 pm
Basic drawing and dimensioning work fine. Still has the "auto generate" messages. It blows up when trying to make a hatched area, but the BT looks like the failure is in Dimensioning.
<PropShape> PropertyTopoShape.cpp(316): auto generate element map: DatumPlane001
<PropShape> PropertyTopoShape.cpp(316): auto generate element map: Pocket001
X Error: BadWindow (invalid Window parameter) 3
  Major opcode: 31 (X_GrabKeyboard)
  Resource id:  0x0
<Part> PartFeature.cpp(186): 16Standard_Failure Shape index out of bound: Pocket001.Vertex31
#0  /lib/x86_64-linux-gnu/libc.so.6(+0x354b0) [0x7fa3f812b4b0]
#1  0x7fa3bff256dc in TopoDS_Shape::ShapeType() const from /home/huxster/Target/asm3-build/Mod/TechDraw/TechDraw.so+0x18
#2  0x7fa3bfaba1ff in Measure::Measurement::getType() from /home/huxster/Target/asm3-build/Mod/Measure/Measure.so+0x1af
#3  0x7fa3bfab9fa1 in Measure::Measurement::addReference3D(App::DocumentObject*, char const*) from /home/huxster/Target/asm3-build/Mod/Measure/Measure.so+0x119
#4  0x7fa3bfab9e86 in Measure::Measurement::addReference3D(App::DocumentObject*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) from /home/huxster/Target/asm3-build/Mod/Measure/Measure.so+0x36
#5  0x7fa3bffed3bd in TechDraw::DrawViewDimension::setAll3DMeasurement() from /home/huxster/Target/asm3-build/Mod/TechDraw/TechDraw.so+0xb3
#6  0x7fa3bffe92ef in TechDraw::DrawViewDimension::onChanged(App::Property const*) from /home/huxster/Target/asm3-build/Mod/TechDraw/TechDraw.so+0x129
#7  0x7fa3fae69e93 in App::Property::touch() from /home/huxster/Target/asm3-build/lib/libFreeCADApp.so+0x41
#8  0x7fa3fae93542 in App::PropertyLinkSubList::updateElementReference(App::DocumentObject*, bool) from /home/huxster/Target/asm3-build/lib/libFreeCADApp.so+0x320
#9  0x7fa3fae88933 in App::PropertyLinkBase::updateElementReferences(App::DocumentObject*, bool) from /home/huxster/Target/asm3-build/lib/libFreeCADApp.so+0x269
#10  0x7fa3fae0ad30 in App::GeoFeature::updateElementReference() from /home/huxster/Target/asm3-build/lib/libFreeCADApp.so+0x1c6
#11  0x7fa3fae0adf6 in App::GeoFeature::onChanged(App::Property const*) from /home/huxster/Target/asm3-build/lib/libFreeCADApp.so+0x5e
#12  0x7fa3d830ed76 in Part::Feature::onChanged(App::Property const*) from /home/huxster/Target/asm3-build/Mod/Part/Part.so+0x27c
#13  0x7fa3b3af3a9e in PartDesign::ProfileBased::onChanged(App::Property const*) from /home/huxster/Target/asm3-build/Mod/PartDesign/_PartDesign.so+0x68
#14  0x7fa3fae69f5d in App::Property::hasSetValue() from /home/huxster/Target/asm3-build/lib/libFreeCADApp.so+0x41
#15  0x7fa3d8338e7e in Part::PropertyPartShape::setValue(Part::TopoShape const&) from /home/huxster/Target/asm3-build/Mod/Part/Part.so+0x176
realthunder
Postby realthunder » Tue Aug 21, 2018 11:49 pm
oops, forgot to test for null shape. Fixed.
Are you testing the Basic_TechDraw_Tutorial.fcstd? I haven't figure out the root cause of the recomputation failure yet. I'll work on it.
