Python3 and Qt5 Compatible Addon Workbenches (in preparation for 0.18)
Post by Kunda1 »
Objective
A forum thread to track migration of 3rd-party FreeCAD-Addons to Py3/Qt5
Feedback kindly requested from all authors/testers of said Workbenches/Addons to help populate this list.
The List
Addons                 Py3     Qt5     Authors
A2plus                  ✔       ✔      kbwbe
AirPlaneDesign          ✔       ✔      a179308
animation               x       x       microelly2
assembly2               x       x       hamish
Autoload                x       x
BIM                     ✔       ✔      yorik
BOLTSFC                 ✔       ✔      bernd
CADExchanger            x       x       yorik
cadquery_module         ✔       ✔      jmwright
Cfd                     x       x
CfdOF                   ✔       ✔
CommandPanel            ✔       ✔      triplus
cura_engine             x       x
Curves                  ✔       ✔      Chris_G
Defeaturing             ✔       ✔      easyw-fc
DesignSPHysics          ✔       ✔
dodo                    ✔       ✔      oddtopus
drawing_dimensioning    x       x
dxf-library             x       x
ExplodedAssembly        ✔       ✔      JMG
fasteners               ✔       ✔      shaise
FCGear                  ✔       ✔      looo
flamingo                x       x       (replaced by dodo wb)
frame                   ✔       ✔      looo
GDT                     x       x
geodata                 x       x
IconThemes              ✔       ✔      triplus
InventorLoader          ✔       x
kerkythea               x       x
kicadStepUpMod          ✔       ✔      easyw-fc
lattice2                ✔       ✔      DeepSOIC
Launcher                ✔       ✔      triplus
Lithophane              ✔       ✔      furti
Manipulator             ✔       ✔      easyw-fc
NavigationIndicator     x       x
nurbs                   x       x
Part-o-magic            ✔       ✔      DeepSOIC
parts_library           x       x
pcb                     x       x
persistenttoolbars      x       x
PieMenu                 ✔       ✔      triplus
pluginloader            x       x
pyrate                  ✔       ✔
reconstruction          x       x
Reinforcement           ✔       ✔      amrit3701
Render                  x       x      yorik
retr3d                  x       x
SelectorToolbar         x       x
sheetmetal              ✔       ✔      shaise
ShortCuts               ✔       ✔      triplus
Silk                    x       x
SlopedPlanes            x       x
symbols_library         x       x
TabBar                  ✔       ✔
timber                  x       x
ToolbarStyle            ✔       ✔      triplus
WebTools                ✔       ✔      yorik
workfeature             ✔       ✔      rentlau_64
yaml-workspace          ✔       ✔      Mambix
Testing
Very quick way to start testing is using the 0.18dev Py3/At5 builds conveniently added by our friend @sgrogan Background
One of the objectives for 0.18 release is that it will be py3 and Qt5 compatible
This are ongoing efforts to make this happen:
issue #995: Python3 compatibility (Ongoing)
issue #2986: Port from Qt4 to Qt5 (Ongoing)
https://github.com/looooo/FreeCAD/issues/8
https://forum.freecadweb.org/viewtopic.php?f=10&t=7713 "PyCXX upgrade" (from 2014)
https://forum.freecadweb.org/viewtopic.php?f=10&t=12534 "Porting to python3" (Active thread)
https://github.com/FreeCAD/FreeCAD-addons/issues/93
Related
FC Macros Py3/Qt5 Tracker https://forum.freecadweb.org/viewtopic.php?f=10&t=30636
Note: this post will be actively updated
easyw-fc
Re: Python3 and Qt5 Compatible Addon Workbenches (in preparation for 0.18)
Post by easyw-fc »
My three wbs should be ready to work both with Py3 & Qt5
     Addons            Py3     Qt5
Defeaturing             *       *
kicadStepUpMod          *       *
Manipulator             *       *
Post by Kunda1 »
easyw-fc wrote: Fri Aug 31, 2018 7:31 am My three wbs should be ready to work both with Py3 & Qt5
:thumbsup:
DeepSOIC
Post by DeepSOIC »
Lattice2 does work on py3+qt5.
Part-o-magic does not work.
tabbar works, at least for me.
DeepSOIC
Post by DeepSOIC »
Suggestion: also add realthunder-ready :mrgreen:
(none of my workbenches are... :oops: )
easyw-fc
Post by easyw-fc »
DeepSOIC wrote: Fri Aug 31, 2018 11:06 am Suggestion: also add realthunder-ready :mrgreen:
I would suggest a different thread.
A3 compatibility will require much more work.
I'm in the process to improve my compatibility with A3 branch. Some of the new containers are already supported, but this new branch has so many new features that the process will take much longer than Py3 and Qt5 compatibility... :)
yorik
Founder
Post by yorik »
Very good initiative @Kunda1! Indeed that's the first thing one notices when starting a py3 session :) several plugins fail to load.
sgrogan
Post by sgrogan »
yorik wrote: Fri Aug 31, 2018 1:54 pm Very good initiative @Kunda1!
+1
A plug for the PY3 builds:
https://github.com/FreeCAD/FreeCAD/rele ... g/0.18_pre
https://launchpad.net/~freecad-maintain ... ecad-daily
Anyone who wants to add some words the the text on the releases page or the PPA is Welcome.
Maybe we could even add something to github/FreeCAD/FreeCAD's read.me?
A call for testing, or the like?
EDIT: Where is the best place to discuss issues?
Ultimately it's best to open an issue on the WB author's Github, but as with FreeCAD itself there is a clear benefit to triage in the forum.
The packaging of these PY3/QT5 compatible builds are in their infancy, and bugs could be due to the packaging as likely as to FreeCAD or the add-on's code.
"fight the good fight"
easyw-fc
Post by easyw-fc »
sgrogan wrote: Fri Aug 31, 2018 4:14 pm +1
Thanks a lot for your builds!
I have been able to fix my WBs because of them!
And I have also OCC7.3 on Windows Conda builds! :D
Thanks again Chris.
Maurice
shaise
Post by shaise »
Fasteners workbench is now compatible with both Qt5 and Py3
