Marked in the thread
Python3 and Qt5 Compatible Addon Workbenches (in preparation for 0.18)
Re: Python3 and Qt5 Compatible Addon Workbenches (in preparation for 0.18)
you forgot to mark DeepSOIC's workbenches...
Hi @shaise
I'm having an issue on updating it by the Addons manager:
File "C:\FreeCAD-0.18-dev_PY3_QT5-x64\Mod\AddonManager\AddonManager.py", line 948, in run
answer = repo.pull()
File "C:\FreeCAD-0.18-dev_PY3_QT5-x64\bin\lib\site-packages\git\cmd.py", line 548, in <lambda>
return lambda *args, **kwargs: self._call_process(name, *args, **kwargs)
File "C:\FreeCAD-0.18-dev_PY3_QT5-x64\bin\lib\site-packages\git\cmd.py", line 1014, in _call_process
return self.execute(call, **exec_kwargs)
File "C:\FreeCAD-0.18-dev_PY3_QT5-x64\bin\lib\site-packages\git\cmd.py", line 825, in execute
raise GitCommandError(command, status, stderr_value, stdout_value)
git.exc.GitCommandError: Cmd('git') failed due to: exit code(1)
cmdline: git pull
stdout: 'Updating 2b60079..18203b2'
stderr: 'From https://github.com/shaise/FreeCAD_FastenersWB
* branch HEAD -> FETCH_HEAD
error: Your local changes to the following files would be overwritten by merge:
FastenerBase.py
screw_maker.py
Please commit your changes or stash them before you merge.
Aborting'
it seems I had the directory in someway locked... now it is working fine...
sorry for the noise
Thanks, although it's just lattice2 that is py3/qt5 compatible at the moment per hos previous post.
I've also marked TabBar
A2Plus assembly workbench should be compatible with Py3/Qt5
KBWBE
latest release: v0.4.56, installable via FreeCAD's addon manager
SheetMetal workbench is now compatible with both Qt5 and Py3
The "Lithophane" Workbench (https://github.com/furti/FreeCAD-Lithophane) is not in your list, because it was added yesterday to the addons repository.
But it is compatible with PY3 and QT5.
Addedfurti wrote: ↑Fri Sep 07, 2018 11:23 am The "Lithophane" Workbench (https://github.com/furti/FreeCAD-Lithophane) is not in your list, because it was added yesterday to the addons repository.
