Possible OCCT bug: Geom2dAPI_InterCurveCurve and GeomAPI_ExtremaCurveCurve and tangency
abdullah
Postby abdullah » Fri Oct 05, 2018 3:55 pm
Dear Community,
I think I have discovered a bug in OCCT, but before reporting it further, I would like to make sure it is indeed a bug, so I appreciate that you read the following lines.
Bug description:
Geom2dAPI_InterCurveCurve and GeomAPI_ExtremaCurveCurve fail to detect intersection between a circumference and a line segment, when the line segment endpoint is on the circumference AND the line is tangent to the circumference. It successfully finds the intersection if the line is NOT tangent (maintaining the point on the circunference the same).
This originated from tracker bug:
https://www.freecadweb.org/tracker/view.php?id=2463
The situation is this:
trimtang.fcstd
(3.61 KiB) Downloaded 9 times
The top line is not detected as intersection because it is tangent.
Standalone reproduction
I have recreated the whole using just OCCT.
The test consist in using both algorithms on the circumference and top line. I first ensure that the endpoint is within the precision asked to the algorithms.
A first pass is with the EXACT geometry above, so tangent line.
A second pass is with the starting point of the line (the one farthest from the circumference) at another position, so that it is NOT tangent.
When the line is tangent the intersection is not detected, when the line is NOT tangent, the intersection is detected.
Question: Am I asking the algorithm something I should not, or is it a bug?
# include <Geom_Circle.hxx>
# include <Geom_Curve.hxx>
# include <Geom_Line.hxx>
# include <Geom_Plane.hxx>
# include <GC_MakeCircle.hxx>
# include <GC_MakeSegment.hxx>
# include <gp.hxx>
# include <gp_Ax2.hxx>
# include <gp_Pnt.hxx>
# include <gp_Dir.hxx>
# include <gp_Pln.hxx>
# include <GeomAPI.hxx>
# include <Geom2d_Curve.hxx>
# include <Geom2dAPI_InterCurveCurve.hxx>
# include <GeomAPI_ExtremaCurveCurve.hxx>
int main()
    double precision = 1.0e-8;
    // A line segment
    gp_Pnt p1(-80.461134694338, 53.07587187722, 0.0), p2(-31.501464018476, 67.029737602069, 0.0);
    GC_MakeSegment ms(p1, p2);
    Handle(Geom_TrimmedCurve) tc_line = ms.Value();
    // A circunference
    gp_Pnt center(-18.339655323916, 20.849340929486, 0.0);
    double radius = 48.019394466707;
    gp_Dir norm(0,0,1);
    gp_Ax2 xdir(center, norm);
    GC_MakeCircle mc(xdir, radius);
    Handle(Geom_Circle) circle = mc.Value();
    // NOTE: The line is made to be substantially tangent to the circunference
    double distance_endpoint_linesegment_to_center_cirncunf = center.Distance(p2);
    printf("SETUP 1:\n");
    printf("========\n");
    printf("Description: Circle with touching tangential line\n\n");
    printf("Distance from endpoint of line segment to center circunf: %f\n", distance_endpoint_linesegment_to_center_cirncunf);
    printf("Distance from circunference to endpoint of line segment: %.10e\n\n", distance_endpoint_linesegment_to_center_cirncunf - radius);
    // Algorithm1: 2D intersection with Geom2dAPI_InterCurveCurve
    gp_Pln plane(gp_Pnt(0,0,0),gp_Dir(0,0,1));
    Handle(Geom2d_Curve) circle2dCurve;
    circle2dCurve = GeomAPI::To2d(circle, plane);
    Handle(Geom2d_Curve) line2dCurve;
    line2dCurve = GeomAPI::To2d(tc_line, plane);
    Geom2dAPI_InterCurveCurve Intersector2d;
    printf("Algorithm: Geom2dAPI_InterCurveCurve - precision/tolerance: %.10g\n",precision);
    Intersector2d.Init(circle2dCurve, line2dCurve, 1.0e-8);
    printf("\tGeom2dAPI_InterCurveCurve - NbPoints: %d\n", Intersector2d.NbPoints());
    printf("\tGeom2dAPI_InterCurveCurve - NbSegments: %d\n", Intersector2d.NbSegments());
    for (int i=1; i <= Intersector2d.NbPoints(); i++) {
        gp_Pnt2d p = Intersector2d.Point(i);
        printf("\t%d: (%f,%f,0)\n",i,p.X(),p.Y());
    // Algorithm2: GeomAPI_ExtremaCurveCurve
    printf("\nAlgorithm: GeomAPI_ExtremaCurveCurve - precision/tolerance: %.10g\n",precision);
    GeomAPI_ExtremaCurveCurve Intersector3d(circle, tc_line);
    printf("\tGeomAPI_ExtremaCurveCurve - NbExtrema: %d\n", Intersector3d.NbExtrema());
    // Setup 2: non tangencial line, same endpoint
    gp_Pnt  p3(-100.0,30.0,0.0);
    GC_MakeSegment ms2(p3, p2);
    Handle(Geom_TrimmedCurve) tc_line2 = ms2.Value();
    double distance_endpoint_linesegment_to_center_cirncunf2 = center.Distance(p2);
    printf("\nSETUP 2:\n");
    printf("Description: Circle with touching NON-tangential line\n\n");
    printf("Distance from endpoint of line segment to center circunf: %f\n", distance_endpoint_linesegment_to_center_cirncunf2);
    printf("Distance from circunference to endpoint of line segment: %.10e\n\n", distance_endpoint_linesegment_to_center_cirncunf2 - radius);
    Handle(Geom2d_Curve) line2dCurve2;
    line2dCurve2 = GeomAPI::To2d(tc_line2, plane);
    Intersector2d.Init(circle2dCurve, line2dCurve2, 1.0e-8);
    GeomAPI_ExtremaCurveCurve Intersector3d2(circle, tc_line2);
    printf("\tGeomAPI_ExtremaCurveCurve - NbExtrema: %d\n", Intersector3d2.NbExtrema());
    return 0;
Compile:
g++ intersector.cpp -I/usr/include/occt -L/usr/lib/x86_64-linux-gnu -lTKG3d -lTKernel -lTKMath -lTKGeomBase -lTKGeomAlgo -o intersector
Execute:
./intersector
OS: Ubuntu 18.04.1 LTS
Version: 0.18.14874 (Git)
Build type: Debug
Branch: _2463_
Hash: 1d3f3ab7ec0b483c4459646e0b1e63c7314c51a5
Python version: 2.7.15rc1
abdullah
Re: Possible OCCT bug: Geom2dAPI_InterCurveCurve and GeomAPI_ExtremaCurveCurve and tangency
Postby abdullah » Sun Oct 07, 2018 10:51 am
Kunda1 wrote:...
Who do you think we can ping into here, who has the knowledge / is interested in OCCT upstream bugs?
easyw-fc
Postby easyw-fc » Sun Oct 07, 2018 12:50 pm
Kunda1 wrote:...
Hi @abdullah
I just filed a bug at OCC Mantis here
https://tracker.dev.opencascade.org/view.php?id=29564
You simply need to register
https://dev.opencascade.org/index.php?q=user/register
and ad a new issue
https://tracker.dev.opencascade.org/log ... t_page.php
abdullah
Postby abdullah » Sun Oct 07, 2018 1:01 pm
Kunda1 wrote:...
Hi @abdullah
and ad a new issue
Hi Maurice!
Thanks! I am registered with them.
I was hoping for some reassurance that this is actually a bug before making them lose their time miserably with me.
I will file the bug with them in a couple of days :)
abdullah
Postby abdullah » Tue Mar 12, 2019 1:09 pm
abdullah wrote:
Mon Oct 08, 2018 1:58 pm
Bug filed against OCCT 7.3:
https://tracker.dev.opencascade.org/view.php?id=30217
A gift courtesy of the Opencascade guys:
Thanks guys! :D :D :D :D
Postby chrisb » Tue Mar 12, 2019 1:49 pm
Does this improve the sketcher/solver situation as well with tangncy+coincidence?
Quaoar
Postby Quaoar » Tue Mar 12, 2019 2:35 pm
The fix is not finalized yet because of many regressions.
FOSS CAD model inspection utility and prototyping framework: http://analysissitus.org
abdullah
Postby abdullah » Wed Mar 13, 2019 12:46 pm
Solver: not at all.
Sketcher: not related to "tangency constraint", but related to detection of intersections, for example when trimming a curve and not getting the right result.
I have applied extra checks in FreeCAD that improve detection in some cases, but it is always nice to have robust intersection algorithms directly from OCCT.
I thought it was. Thanks for the heads-up. Hopefully eventually will... ;)
