Code quality checker
PrzemoF
Postby PrzemoF » Mon Dec 03, 2018 5:31 pm
I'm not really sure if we want to use it, but discussing it won't hurt :D It's an automated code quality checker linked with github. Looks like it works in a similar manner as travis-ci.
https://houndci.com/
yorik
Site Admin
Re: Code quality checker
Postby yorik » Tue Dec 04, 2018 8:54 pm
Would be worth a try!
PrzemoF
Postby PrzemoF » Tue Dec 04, 2018 9:59 pm
python: http://help.houndci.com/configuration/flake8
I don't see anything for c++ and I'm not sure what would happen with c++ or mixed patches.
saso
Postby saso » Wed Dec 12, 2018 6:32 pm
maybe https://www.sonarqube.org/ https://sonarcloud.io/
PS: also note that we already use:
- C++ compiler (clang, gcc, msvc) warnings
- C++ compiler static code analyzers "msvc /analyze" and "clang scan-build"
- Coverity (C++ and python) https://forum.freecadweb.org/viewtopic.php?f=10&t=16966
- PVS-Studio (C++) https://forum.freecadweb.org/viewtopic.php?f=10&t=34266
- LGTM (python) https://lgtm.com/projects/g/FreeCAD/FreeCAD/
- Cppcheck (C++) for some basic checks of the C++ code
- flake8 (python) for some of the python code
and for the future I am looking more in to sanitizers and fuzzers
https://github.com/google/sanitizers
http://lcamtuf.coredump.cx/afl/
https://github.com/googleprojectzero/winafl
https://github.com/google/honggfuzz
https://llvm.org/docs/LibFuzzer.html
https://github.com/google/oss-fuzz
What's the Use of Dynamic Analysis When You Have Static Analysis?
https://www.viva64.com/en/b/0643/
In-Depth: Static Code Analysis
https://www.gamasutra.com/view/news/128 ... alysis.php
Static Analysis at Scale: An Instagram Story
https://instagram-engineering.com/stati ... 498ab71a0c
AddressSanitizer (ASan) for Windows with MSVC
https://devblogs.microsoft.com/cppblog/ ... with-msvc/
PrzemoF
Postby PrzemoF » Wed Dec 12, 2018 6:45 pm
Looks very promising, but after I selected online analysis I hit some code that must be run locally:
"Download and unzip the Scanner for Linux
And add the bin directory to the PATH environment variable
Download
Execute the Scanner from your computer
Running a SonarCloud analysis is straighforward. You just need to execute the following commands in your project's folder."
I'm not sure if I'm doing something wrong or that's the way it's supposed to be.
saso
Postby saso » Wed Dec 12, 2018 6:55 pm
I have not used sonar yet, here are some instructions how to set sonarcloud up with travis https://docs.travis-ci.com/user/sonarcloud/
saso
Postby saso » Fri Dec 28, 2018 9:49 am
I have seen you have started an Coverity build for FreeCAD, but you already have access to https://scan.coverity.com/projects/saso ... ac-freecad ;)
Check the three post here https://forum.freecadweb.org/viewtopic. ... 30#p210644 for some first steps how to use it.
saso
Postby saso » Sun Jan 06, 2019 11:26 pm
Control source code quality using the SonarQube platform
https://www.viva64.com/en/b/0452/
PVS-Studio as a plugin for SonarQube
https://www.viva64.com/en/b/0513/
Edit: I have moved some info about the PVS-Studio to a separate topic https://forum.freecadweb.org/viewtopic.php?f=10&t=34266
Postby Kunda1 » Sat Oct 19, 2019 1:21 pm
a thread pertaining to LGTM was split, new thread is at: https://forum.freecadweb.org/viewtopic.php?f=10&t=40228
saso
Postby saso » Sat Oct 19, 2019 3:37 pm
Thanks Kunda1 for moving lgtm to its own topic...
And to give a small update to this topic (related but not directly :roll:), link to a ton of videos from this (and past) years CppCon presenting and discussing different topics, best practices and the future of developing in C++ https://www.youtube.com/user/CppCon/videos
