Code quality checker
Jee-Bee
Re: Code quality checker
Postby Jee-Bee » Wed Jun 12, 2019 5:28 pm
Not that i know of
[quote=bernd user_id=2069]
ping
[/quote]
Works (Don't forgot the user ID).
bernd wrote: ping
bernd
Postby bernd » Fri Jun 21, 2019 11:45 am
Had a look at this, it finds some problems which are not found by pep8. It's great
https://lgtm.com/projects/g/FreeCAD/Fre ... de=heatmap
bernd
Postby bernd » Fri Jul 05, 2019 4:08 pm
It seams possible to exclude files from analysis ... https://lgtm.com/help/lgtm/customizing- ... sification
Zhis would make sense for the following file: https://github.com/FreeCAD/FreeCAD/blob ... sign.py#L1
It s autogenerated and has 881 allerts !!! https://lgtm.com/projects/g/FreeCAD/Fre ... de=heatmap
saso
Postby saso » Sat Jul 06, 2019 12:36 pm
I will look in to it when I will try to make it work for C++
bernd
Postby bernd » Mon Jul 08, 2019 7:51 am
That would be great!
BTW: Path and Fem really reduced lgtm alerts. I found some surprising bugs I would never ever have found without ...
bernd
Postby bernd » Mon Jul 08, 2019 7:54 am
somehow lgtm is missing files in FEM ...
saso
Postby saso » Mon Jul 08, 2019 9:10 am
Great, this is what this tools are for... There are a few FEM related issues reported also in Coverity, if you maybe want to kill some more bugs ;)
Check the three posts I made here for some basic help on how to use it https://forum.freecadweb.org/viewtopic. ... 30#p210644
There is an "show excluded files" checkbox at the top with some more information about this.
bernd
Postby bernd » Mon Jul 08, 2019 11:04 am
ahh, ok. Would you move these files out of excluded files? They should be analysed as any other file in FEM.
saso
Postby saso » Mon Jul 08, 2019 11:23 am
They are analyzed (check the test files from some other workbenches, they show alerts), they are just excluded from the statistics... I would leave it as it is. https://lgtm.com/help/lgtm/file-classification
saso
Postby saso » Fri Jul 12, 2019 9:49 am
Small update on the LGTM C++ analysis... Unfortunately FreeCAD project is much too big for how the LGTM service is set up currently. A test build timed out after 5h and the build was done only about 38%. So it seems like it will be python only for now.
I have created a pull request for the lgtm analysis configuration file with the file classification for a few generated python files, including the config_control_design.py mentioned by bernd. https://github.com/FreeCAD/FreeCAD/pull/2336
