However, when I try to type those command, it will show error message "identifier "BRepTools_Write" is undefined "or "Module "TKDraw.dll" not found."Using Visual Studio debugger
Command window
Visual Studio debugger provides the Command Window (can be activated from menu View / Other Windows / Command Window), which can be used to evaluate variables and expressions interactively in a debug session (see http://msdn.microsoft.com/en-us/library/c785s0kz.aspx). Note that the Immediate Window can also be used but it has some limitations, e.g. does not support aliases.
When the execution is interrupted by a breakpoint, you can use this window to call the above described functions in context of the currently debugged function. Note that in most cases you will need to specify explicitly context of the function by indicating the name of the DLL where it is defined.
For example, assume that you are debugging a function, where local variable TopoDS_Edge anEdge1 is of interest. The following set of commands in the Command window will save this edge to file edge1.brep, then put it to DRAW variable e1 and show it maximized in the axonometric DRAW view:
>? ({,,TKBRep.dll}BRepTools_Write)("d:/edge1.brep",(void*)&anEdge1)
0x04a2f234 "d:/edge1.brep"
>? ({,,TKDraw.dll}DBRep_Set)("e1",(void*)&anEdge1)
0x0369eba8 "e1"
>? ({,,TKDraw.dll}Draw_Eval)("donly e1; axo; fit")
0x029a48f0 ""
does anyone have any idea about how to config visual studio to make it work?
Thanks
