Has FreeCAD implemented all of interfaces of OCCT?
I ever seen that FreeCAD can build a box withBRepPrimAPI_makebox(length,width,height,[pnt,dir]).However, In the API of OCCT, there are so many other methods to create a box,for example create a box with BRepPrimAPI_MakeBox (const gp_Pnt &P1, const gp_Pnt &P2). How can I extend this function in FreeCAD?
- wandererfan
Re: Has FreeCAD implemented all of interfaces of OCCT?
Function makeBox() in Part module file App/AppPartPy.cpp implements the Python function Part.makeBox().JOE_FU wrote: ↑Sat Jan 12, 2019 7:25 am I ever seen that FreeCAD can build a box withBRepPrimAPI_makebox(length,width,height,[pnt,dir]).However, In the API of OCCT, there are so many other methods to create a box,for example create a box with BRepPrimAPI_MakeBox (const gp_Pnt &P1, const gp_Pnt &P2). How can I extend this function in FreeCAD?
You could add support for different signatures by adding adding new "PyArg_ParseTuple" tests and logic. See makeRevolution() in the same file for an example of using multiple signatures.
wandererfan wrote: ↑Sat Jan 12, 2019 1:49 pmFunction makeBox() in Part module file App/AppPartPy.cpp implements the Python function Part.makeBox().JOE_FU wrote: ↑Sat Jan 12, 2019 7:25 am I ever seen that FreeCAD can build a box withBRepPrimAPI_makebox(length,width,height,[pnt,dir]).However, In the API of OCCT, there are so many other methods to create a box,for example create a box with BRepPrimAPI_MakeBox (const gp_Pnt &P1, const gp_Pnt &P2). How can I extend this function in FreeCAD?
First, Thanks for your reply. Second, there are also two questions I want to pose:
If I want to use a variety of methods of a function, do I need to first determine the parameter type in the makeBox function? and then perform different methods according to different parameter types. Another problem is that when I customize a new make method in AppPartPy.cpp, such as makeMyShape, and add a new method in the add_varargs_mothod method above, but after compiling, there is an error message, suggesting that I have no definition.
add_varargs_method("makeMyBox", &Module::makeMyShape,
"makeMyBox(length,width,height,[pnt,dir]) -- Make a My define box located\n"
"in pnt with the dimensions (length,width,height)\n"
"By default pnt=Vector(0,0,0) and dir=Vector(0,0,1)"
Py::Object makeMyBox(const Py::Tuple& args)
error: "makeMyShape" is not the member of "Part::Moudle"
Thanks for your help.
- wandererfan
Usually it is done like this:
Py::Object makeMyShape(const Py::Tuple& args)
if (PyArg_ParseTuple(args.ptr(), "O!|dddO!O!O!", &(GeometryPy::Type), &pCrv,
&vmin, &vmax, &angle,
&(Base::VectorPy::Type), &pPnt,
&(Base::VectorPy::Type), &pDir,
&(PyType_Type), &type)) {
//do stuff unique to this signature
} else if (PyArg_ParseTuple(args.ptr(), "O!O!", &(GeometryPy::Type), &myParm1,
&myParm2) {
} else {
// error, unsupported signature
//do stuff common to all signatures
You have: add_varargs_method("makeMyBox", &Module::makeMyShape,
but it should be: add_varargs_method("makeMyShape", &Module::makeMyShape,
wandererfan wrote: ↑Mon Jan 14, 2019 2:08 pmUsually it is done like this:Code: Select all
Py::Object makeMyShape(const Py::Tuple& args) { ... if (PyArg_ParseTuple(args.ptr(), "O!|dddO!O!O!", &(GeometryPy::Type), &pCrv, &vmin, &vmax, &angle, &(Base::VectorPy::Type), &pPnt, &(Base::VectorPy::Type), &pDir, &(PyType_Type), &type)) { //do stuff unique to this signature ... } else if (PyArg_ParseTuple(args.ptr(), "O!O!", &(GeometryPy::Type), &myParm1, &myParm2) { //do stuff unique to this signature ... } else { // error, unsupported signature } //do stuff common to all signatures ...
I am so sorry that I wrote the code wrongly.
My code is as follows:
//AppPartPy.cpp
/*test*/
throw Py::ValueError("delta x2 of wedge is negative");
The error was the same as that I mentioned earlier.
Error 48 error C2065: "makeMyShape": Undeclared identifier D:\FreeCAD0.16\FreeCAD-0.16\src\Mod\Part\App\AppPartPy.cpp
Error 47 error C2039: "makeMyShape": Not a member of "Part::Module" D:\FreeCAD0.16\FreeCAD-0.16\src\Mod\Part\App\AppPartPy.cpp
- wandererfan
Are you trying to compile v0.16? That is a very old version, there are people developing v0.19 now.
I don't use Windows, but your code compiles and runs
>>> import Part
>>> Part.makeMyShape()
ValueError: delta x2 of wedge is negative
OS: Linux Mint 19 Tara
Version: 0.18.15611 +1 (Git)
Build type: debug
Branch: dToolsv2
Hash: bc6a299ef9587cdec37e375143d91f54df9bfe9c
Python version: 2.7.15rc1
OCC version: 7.2.0
Maybe one of the Windows developers has a clue?
wandererfan wrote: ↑Tue Jan 15, 2019 1:14 pmAre you trying to compile v0.16? That is a very old version, there are people developing v0.19 now.
I don't use Windows, but your code compiles and runsin this environment:Code: Select all
>>> import Part >>> Part.makeMyShape() Traceback (most recent call last): File "<input>", line 1, in <module> ValueError: delta x2 of wedge is negative >>>
Build type: debug
Branch: dToolsv2
OCC version: 7.2.0
OK,Thank you very much. Maybe this is a version issue or a operating system issue.
I am going to try other more advanced versions.
