Sketcher constraint dialog problem
Joel_graff
Postby Joel_graff » Wed Jan 23, 2019 10:18 am
Downloaded the latest AppImage and was modifying a sketcher constraint when the dialog popped up looking like this:
Screenshot from 2019-01-23 04-15-05.png (9.17 KiB) Viewed 173 times
OS: Pop!_OS 18.10
Version: 0.18.15671 (Git) AppImage
Hash: 28cbe2bd8986701bb7404842cf60138957e23ed6
Python version: 3.6.7
Qt version: 5.6.2
You can find the FreeCAD Trails workbench for transportation engineering on my github at:
https://www.github.com/joelgraff/freecad.trails
triplus
Re: Sketcher constraint dialog problem
Postby triplus » Wed Jan 23, 2019 8:42 pm
Likely the issue should be reported against the System76 Pop GTK+ Theme:
https://github.com/pop-os/gtk-theme
Some solutions:
  • You could add the PPA and install/update the theme to the latest version. To see if the issue was already resolved. Note that from the PPA they provide some other packages. And therefore if you want to update only the theme you will likely need to take care of that manually (apt). And after to remove the PPA.
  • Use different Linux theme not having such issues.
  • Set and use one of the FreeCAD Stylesheets from FreeCAD preferences.
  • Create and set a minimal FreeCAD stylesheet, that will provide better styling for such Qt widgets.
triplus
Postby triplus » Wed Jan 23, 2019 10:56 pm
Note that i tested it and the theme related package on the PPA is the same as the one provided by default. Therefore this is a current issue with System76 Pop GTK+ Theme.
P.S. Feel free to report it to them if you would like to get it fixed.
