Determine Scale of 3D View?
wandererfan
Postby wandererfan » Thu Feb 28, 2019 6:37 pm
Is the scale of the 3D view available anywhere? For example, if the standard 10mm Cube's on screen image is 20mm across then the scale would be 2:1. If the scale is not available, what about the parameters to calculate it?
I found "SbViewVolume::getWorldToScreenScale" but I can not understand the resulting values. If our cube is 40mm on the screen, getWorldToScreenScale returns ~20. 20 what to 1 what?
Any advice appreciated.
microelly2
Re: Determine Scale of 3D View?
Postby microelly2 » Fri Mar 01, 2019 8:46 am
I use the camera properties focal lenght, height Angle
see SoCamera manumal
regis
Postby regis » Fri Mar 01, 2019 1:09 pm
Where did you find this?
Please explain more, howw do you use it to have your drawings to a certain scale in 3D view,\
Another question, is it possible to have a 3D view window inside of the main 3D space where all the modeling is done? for example like a view port, if I draw a box, or any flat shape, and tell it to be a view port, can I insert a 3d view inside that shape?
DeepSOIC
Postby DeepSOIC » Fri Mar 01, 2019 1:24 pm
For Lattice Autosize, I use camera properties to figure out the scale. It's not straightforward.
https://github.com/DeepSOIC/Lattice2/bl ... #L102-L125
Interesting, that might simplify Lattice autosize a little bit. 20 is likely "20 pixels per 1 mm". You need to know your screen's pixel density to match to size on your screen, and AFAIK this value is difficult if not impossible to obtain from the OS.
microelly2
Postby microelly2 » Fri Mar 01, 2019 1:38 pm
I use this command
camt='#Inventor V2.1 ascii\n\n\nOrthographicCamera {\n viewportMapping ADJUST_CAMERA\n position 0 0 1\n orientation .00 0.00 -1.0 4.7123\n nearDistance -54.94503\n farDistance 515.51514\n aspectRatio 1\n focalDistance 5\n height 500\n\n}\n'
FreeCADGui.activeDocument().activeView().setCamera(camt)
to get the window to 500 mm
if the window is not quadratic the min dimension is 500 mm
in the picture the cylinder has a radius of 250. when i scale the window the cylinder/circle always connects to borders of the window.
regis
Postby regis » Fri Mar 01, 2019 5:12 pm
I use this command
Thanks in what folder will I see this information related to this code commands?
How do you use this?
wandererfan
Postby wandererfan » Fri Mar 01, 2019 6:04 pm
https://grey.colorado.edu/coin3d/classS ... df1447c780
It's used a few places in Gui, but I don't understand it yet.
DeepSOIC
Postby DeepSOIC » Fri Mar 01, 2019 6:14 pm
For Lattice Autosize, ...
It is the inverse of what you need. Find out how large one pixel on your screen is. Then Invert the math of my module to achieve what you need. Sorry, I don't have it pre-made, yet.
wandererfan
Postby wandererfan » Sat Mar 02, 2019 3:39 pm
Awesome hints, DeepSOIC, thanks.
I can now put a correctly scaled 3D window grab onto a TD Page.
