Future of Travis CI...
apeltauer
Re: Future of Travis CI...
Postby apeltauer » Mon Mar 11, 2019 6:36 pm
I have my own gitlab instance running on a server in my local network.
My build machine is a pc running windows 10, it just compiles and runs test...
My gitlab Ci configuration file is not just a one liner. So I don’t think it make seen to post it here. But basically it is nearly the same then the other Ci’s Like Travis...
Define stages (steps). In the stages you can define steps in before scrip, script (main step), after script...
That’s all... then you have the possibility to save artifacts which can be used in later stages.
See https://docs.gitlab.com/ee/ci/quick_start/
PrzemoF
Postby PrzemoF » Mon Mar 11, 2019 7:09 pm
Thanks for the info!
apeltauer
Postby apeltauer » Mon Mar 11, 2019 8:34 pm
Your welcome. Maybe we could check out if gitlab.com
Is providing a Ci runner for windows/linux in the internet...
ezzieyguywuf
Postby ezzieyguywuf » Sat Mar 16, 2019 12:21 am
If you’d like to see a working sample, you can take a look at my OccWrapper project on gitlab. It is a very basic, very incomplete c++ wrapper around opencascade.
here is the ci config. It is pretty straightforward and the gitlab documentation is very good.
I don’t mind answering questions you may have, though I’m far from an expert.
PrzemoF
Postby PrzemoF » Sat Mar 16, 2019 4:35 pm
I did some tests as well, but I'm having problem figuring our what's the system Seems to be some debian/ubuntu (apt-get). My (failing) config for building CalculiX [1]
[1] https://gitlab.com/PrzemoF/calculix-bui ... lab-ci.yml
ezzieyguywuf
Postby ezzieyguywuf » Sat Mar 16, 2019 11:18 pm
...I'm having problem figuring our what's the system...
@PrzemoF, the CI system on Gitlab uses Docker containers, much the same as travis-ci does (I believe).
You can see here on my config that the first line specifies an "image" variable, which uses my own custom Docker image.
You can get more info here on the gitlab documentation
