Release notes for v0.19
Re: Release notes for v0.19
Postby Kunda1 » Mon Aug 26, 2019 11:27 pm
Darker stylesheets by @pablogil
Joel_graff
Postby Joel_graff » Tue Aug 27, 2019 11:50 am
+1 on that one. Really have appreciated using them. :)
Anyway, looks like I have a little catching up to do this weekend on the release notes. :)
triplus
Postby triplus » Tue Aug 27, 2019 1:37 pm
triplus
Postby triplus » Thu Aug 29, 2019 10:21 pm
Path: coolant management
https://forum.freecadweb.org/viewtopic. ... 10#p329868
Draft: massive amount of TechDraw support added
https://forum.freecadweb.org/viewtopic.php?f=35&t=38940
TechDraw: improved SVG export, navigation and more end user control over the recompute routine
https://github.com/FreeCAD/FreeCAD/pull/2455
https://github.com/FreeCAD/FreeCAD/pull/2458
https://github.com/FreeCAD/FreeCAD/pull/2468
Part: new command create points from mesh
https://github.com/FreeCAD/FreeCAD/pull/2450
Not as massive one but Wayland has been such a buzzword in the past decade:
https://github.com/FreeCAD/FreeCAD/pull/2466
Joel_graff
Postby Joel_graff » Sat Aug 31, 2019 8:15 pm
triplus wrote:
Tue Aug 20, 2019 1:09 pm
This could go somewhere in the Core/Assembly section
There really doesn't seem to be an appropriate sport for that. Can you maybe take a look and identify where it ought to go? Can add a section as well, if that seems best.
triplus
Postby triplus » Sat Aug 31, 2019 8:36 pm
People will likely understand it best, if you put it under Assembly. If you would write something like App::Link section, good luck with that.
P.S. In addition (in 2019/2020) it's about time FreeCAD release notes do get an Assembly section. ;)
Joel_graff
Postby Joel_graff » Sat Aug 31, 2019 10:03 pm
DeepSOIC wrote:
Fri Aug 23, 2019 8:34 pm
Also a new thing: dynamic properties, addable through property editor.
I'm thinking of adding a "Core" section to the release notes, as there's another feature add that appears to fit there. Unless this belongs somewhere specific?
EDIT: Modified the User Interface notes in the general section to handle it. It's a WIP, anyway.
Joel_graff
Postby Joel_graff » Sat Aug 31, 2019 10:50 pm
Will do. I had thought of that, but then realized "Assembly" is still outsourced to external workbenches, so it made me wonder where to put it.
mario52
Postby mario52 » Sun Sep 01, 2019 3:39 pm
hi
other good addition (again one macro become useless Image)
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Dialog creation. My macros on Gist.github.
Joel_graff
Postby Joel_graff » Tue Sep 03, 2019 3:43 am
hi
can you describe what this is a little more clearly?
