Does Freecad support physics stimulation? I am used to Grasshopper (kangaroo) and Rhino. I want to create a tensile structure and want a minimum surface from a mesh.
Thank you.
https://www.youtube.com/watch?v=zeRe57uoEJQ
physics stimulation
- Joel_graff
Re: physics stimulation
There has been an attempt to provide physics support in FreeCAD with bullet phyiscs:adnanmakda95 wrote: ↑Tue Mar 12, 2019 2:49 pm Does Freecad support physics stimulation? I am used to Grasshopper (kangaroo) and Rhino. I want to create a tensile structure and want a minimum surface from a mesh.
https://forum.freecadweb.org/viewtopic.php?t=22164
The author created it a couple of years ago and has done nothing since, so far as I can tell.
hmm. i do not know if bullet is suiteable for this, OP wants to generate geometries with physics "stimulation?" in contrast to "simulate" interaction between geometries.Joel_graff wrote: ↑Wed Mar 13, 2019 1:41 am There has been an attempt to provide physics support in FreeCAD with bullet phyiscs:
- Joel_graff
I assumed it was a typo on the part of the OP as I looked to see if there's a such thing and found nothing (I'm not a physics guy, but I enjoy pretending to be one from time-to-time ).
In any case, now that I look closer, Kangaroo is a .NET physics library... It's probably not possible to integrate it without dragging mono or .NET Core into the mix.
we are on the same levelJoel_graff wrote: ↑Wed Mar 13, 2019 12:16 pm I'm not a physics guy, but I enjoy pretending to be one from time-to-time
its probably possible to achive the same results with pybullet:
https://github.com/bulletphysics/bullet3/issues/1926
I had a discussion about physics simulation with realthunder in one of the assembly threads. He had plans to add support for simulation in asm3/link3, but suspect nothing is implemented yet.
gazebo have implemented an abstraction layer to support multiple physics engines, my proposal is to reuse that.
http://gazebosim.org/blog/feature_physics
https://bitbucket.org/ignitionrobotics/ign-physics/
- Joel_graff
I've used gazebo before - had to build a drone simulator for a contract a couple of years ago. I had it mostly done, tehn realized gazebo didn't work on Windows. Tried to help them package for Win, but it turned out it was easier just to use Unity3D instead.fosselius wrote: ↑Wed Mar 13, 2019 1:38 pm gazeboo have implemented an abstraction layer to support multiple physics engines, my proposal is to reuse that.
All the same, a physics engine abstraction layer would be a really valuable addition.
