AppImages of v0.18 release builds
looo
Re: AppImages of v0.18 release builds
Postby looo » Mon Apr 15, 2019 8:21 pm
easyw-fc wrote:
Mon Apr 15, 2019 4:48 pm
is it possible to have a direct link to download and test the latest?
Both 0.19 and 0.18_stable should have the fix included:
0.18.1: https://github.com/FreeCAD/FreeCAD/rele ... e.AppImage
0.19: https://github.com/FreeCAD/FreeCAD/rele ... 4.AppImage
I guess these links are broken once the next iteration is done.
please help with my conda-packaging efforts: https://liberapay.com/looooo/
minimalistic blog: https://looooo.github.io/mini-blog/
easyw-fc
Postby easyw-fc » Mon Apr 15, 2019 8:49 pm
But in which way I would know i.e. if FreeCAD_0.18_stable.AppImage has changed?
both the AppImages have the same errors atm.
triplus
Postby triplus » Mon Apr 15, 2019 9:07 pm
looo wrote:
Sun Apr 14, 2019 6:58 pm
thanks @ triplus for repairing the automatic upload of appimages! This definitely deserve some beer.
Thanks. Note that today i started debugging the upload script a bit. To see on why we can't deploy to 0.18.1 ATM. Hopefully in a day or two i will have something to share. After i can try to help out with the remaining reported AppImage issues.
I will eventuelly switch to use git directly for getting the sources. It's not recommended by conda-forge, thats why I never used it (I guess because checksums should be used). The other way is to provide releases also on the freecad channel, which I already did for 0.18.1 and old toolchain.
And what is the version of glibc used in the new toolchain? I suspect it is not glibc 2.12 anymore? That could explain the issue i reported, regarding libstdc++.so.6 version, being i guess too old on Ubuntu 16.04.
If necessary we can switch the release back to the old toolchain which didn't had much issues with hard-coded paths.
So maybe it's possible to make release builds use conda-forge/label/cf201901 and freecad/label/dev_cf201901?
If my assumption above is correct, indeed. And lets worry about the new toolchain once Qt of greater version will be made available on Conda. As it will likely require newer version of glibc anyway (QtWebEngine). But then the benefits, of having newer Qt, should outweigh the cons.
P.S. Lets use the same toolchain and settings you have used during 0.18_pre. Fixing the FreeCAD 0.18.1 version info would be nice. This two things alone should improve things already. Go ahead and make the needed changes in AppImage repo in the following days. Note that the GTK2 workaround didn't fix the theming issue on my side for now, testing the latest AppImage.
looo
Postby looo » Mon Apr 15, 2019 9:29 pm
I think this hasn't changed. conda-forge still uses the same docker container (centos-6 based).
https://github.com/conda-forge/docker-i ... kerfile#L1
I guess there is currently no way to see if the build has changed.
What does same error mean? Performance issues? Can you give the procedure to reproduce these issues? Maybe this is not related to the appimage, but the new toolchain. If this is the case it should be reproduceable with conda-environment directly.
easyw-fc
Postby easyw-fc » Tue Apr 16, 2019 8:30 am
I have a big delay when launching my script. The script trigs many times the following error
(FreeCAD:7348): GdkPixbuf-WARNING **: 21:48:09.160: Cannot open pixbuf loader module
and this should be the main culprit.
I will create a screencast to show it and to help in reproduce the issue.
At the same time I'm going to wait for the next Appimage build to see if this has been solved.
Thanks for your work on Conda :D
Maurice
looo
Postby looo » Tue Apr 16, 2019 10:04 am
strange. I thought this was solved with one of the previous commits. Stable is now back to old-toolchain and py36. Sorry for this up and down mess.
The documentation (f1) still doesn't work.
ps.: Does anyone know where the path to the qt-assistant (assistant) is set? Which library uses this binary?
All I get is this:
Unable to launch Qt Assistant (/home/travis/build/FreeCAD/FreeCAD-AppImage/conda/linux_stable/AppDir/usr/bin/assistant)
triplus
Postby triplus » Tue Apr 16, 2019 9:58 pm
Yes, this makes much sense, as it was extensively tested during the whole 0.18_pre cycle. Changing things like toolchain, just days before doing a release, that therefore turned out to be a bit problematic approach. For stable builds we should use the old toolchain for now. On daily builds we can experiment more.
I can confirm that on my side all reported issues, by me, are fixed now (FreeCAD 0.18 stable AppImage). I can take a look at the Qt Assistant situation in the following days. Regarding investigating deployment related issues, deploying to latest release, i believe i narrowed the issue down and this should get resolved shortly.
P.S. Anybody testing stable AppImage/macOS builds, make sure you always download the latest available stable AppImage/DMG, before doing the tests, as downloaded one is likely outdated already.
triplus
Postby triplus » Tue Apr 16, 2019 10:14 pm
Reference (FreeCAD 0.19 AppImages using the new toolchain):
https://forum.freecadweb.org/viewtopic. ... 10#p301747
https://forum.freecadweb.org/viewtopic. ... 93#p301767
P.S. Eventually we will need to understand the underlying issue better (libstdc++.so.6) and try to find a fix for it. For now fine tuning FreeCAD 0.18 AppImage experience is a priority.
leong
Postby leong » Tue Apr 16, 2019 11:38 pm
I downloaded the stable AppImage today and When it opens, it opens on a blank page. I am running:
OS: Mageia 6
Version: 0.18.16110 (Git) AppImage
Branch: (HEAD detached at 0.18.1)
Python version: 3.6.7
Qt version: 5.6.2
If I click on <View><Workbench><Start> the program crashes and gives the following
/tmp/.mount_FreeCAYT76bg/AppRun: line 11: 11789 Segmentation fault      (core dumped) ${HERE}/usr/bin/FreeCAD "$@"
I can open other Workbenches, but trying to open 'Star' crashes the program everytime and gives a segmentation fault and there is no further information
Thank you
looo
Postby looo » Wed Apr 17, 2019 4:26 am
What is "Star"?
