AppImages of v0.18 release builds
jmaustpc
Re: AppImages of v0.18 release builds
Postby jmaustpc » Wed Apr 17, 2019 6:09 am
looo wrote:
Wed Apr 17, 2019 4:26 am
leong wrote:
Tue Apr 16, 2019 11:38 pm
I can open other Workbenches, but trying to open 'Star' crashes the program everytime
What is "Star"?
i think its just a typo, he means "Start" workbench
easyw-fc
Postby easyw-fc » Wed Apr 17, 2019 8:49 am
looo wrote:
Tue Apr 16, 2019 10:04 am
strange. I thought this was solved with one of the previous commits. Stable is now back to old-toolchain and py36. Sorry for this up and down mess.
Hi @looo thank you again for your work with appimage and conda.
I just started to use appimage late because I have just moved my personal pc from win10 to mint tessa.
FC 0.18.1 installed from PPA is just fast and clean also with all my WBs.
Using the stable Appimage, all the previous errors are gone [ FC 0.18 16110 (Git) BuildRevisionDate = 2019/04/04 RevisionHash = f7dccfaa909e5b9da26bf50c4a22ccca9bb10c40 ]
... but also with this appimage I'm still getting some performance issues...
I'm investigating to reduce the affected area that is triggered by my importing script...
I'll report it here later...
Xav-83
Postby Xav-83 » Wed Apr 17, 2019 4:15 pm
Hi all,
when I want to open a workshop, I have this error message.
as requested in the other thread, I transmit this information:
OS: Ubuntu 16.04.6 LTS (LXDE/Lubuntu)
Version: 0.19.16475 (Git) AppImage
Hash: 5d211d87049f8dff90e12eace8c4d3f2684a90a1
Python version: 3.7.1
Qt version: 5.6.2
Locale: French/France (fr_FR)
with "Version: 0.19.16207 (Git) AppImage" , I did not have this problem
PS: I did not intervene in the folder / usr / lib / freecad / Mod, nor even in ./Freecad
looo
Postby looo » Wed Apr 17, 2019 7:14 pm
yes it would be interesting to see if these performance issues are related to conda or appimage.
Hi all,
I pushed a commit to ship the the libstdc++ within the appimage (0.19). I am not sure if libstdc++ is shiped with conda for the new toolchain or if this package only contains a link to system libstdc++... We will see.
What is "Star"?
ok this makes sense.
@triplus I see 0.18.1-stable not uploaded anymore. Also I am not sure if 0.19 is uploaded correctly. Do you know what is going on?
sgrogan
Postby sgrogan » Wed Apr 17, 2019 9:02 pm
For 0.18.1 I noticed this as well, maybe something with the "pruning"?
What issue are you seeing with 0.19_pre?
"fight the good fight"
triplus
Postby triplus » Thu Apr 18, 2019 12:37 am
Sometimes a glitch can occur and for build or deploying phase to fail. It doesn't happen often and when it happens it's usually high load or network related. I took a quick look in the logs and it looks like an issue occurred regarding setting up Conda environment and the creation of the stable AppImage/DMG failed as a result. Such things usually get sorted out in less then 24 hours (next build). I manually triggered Travis build and binaries have been created and deployed successfully. As some might notice now we can deploy successfully to 0.18.1. A small change in the upload script is needed. As name and tag_name can differ. I temporary patched the travis.yml directly. As i don't know if ports cache repo is still maintained or not ATM. Next week i will try to make deployment to latest release working automatically. Update information for stable AppImage was restored (using latest).
P.S. I investigated the Qt Assistant issue a bit today and i feel i now have a general overview. I need to test a few things and i am not sure if i will have time to do that tomorrow or during the next week.
triplus
Postby triplus » Thu Apr 18, 2019 1:06 am
@Xav-83
I can confirm libstdc++ issue was resolved testing the latest FreeCAD 0.19 AppImage. Theme still does look "old", only on FreeCAD 0.19.
@easyw-fc
Performance issue could be (low) Qt 5 (version) related. For example i still compile against slightly older version of Qt 5, compared to the one in AppImage, on Ubuntu 16.04. And (viewport) performance is much slower over there. Therefore newer Qt 5 versions might improve performance, when available on Conda.
@leong
If you temporary rename hidden .FreeCAD folder located in your home folder, and start the AppImage, does the issue persist?
P.S. Once some people can confirm FreeCAD 0.18.1, provided on releases page, works on the macOS, after Download page should get updated.
looo
Postby looo » Thu Apr 18, 2019 8:51 am
@triplus seems to have it solved. I see 18.1 appimage and dmg uploaded to github release page.
Then this was a simple fix. Does this mean the appimage should also work on something like alpine-linux?
regarding the theming issue: Maybe including some other removed packages will also get the theme back. Maybe we should look for a solution to avaoid the gtk messages.
regarding dmgs:
Currently the conda-packages are not very stable (crash). If the problem is really caused by qt5.6.2 [1] maybe updating to 5.6.3 is a solution. If these versions are binary-compatible we can try to force the appimage using this version.
[1] https://bugreports.qt.io/browse/QTBUG-57404
looo
Postby looo » Thu Apr 18, 2019 10:58 am
I see the pixbuf problem wasn't solved. I made some tests and it seems like setting
export QT_STYLE_OVERRIDE=gtk2
vanishes the warning. But gui doesn't look good.
Conda sets up some configuration files after the installation [1]. This adds the problems for the portable appimage.
Searching for similar problems I found [2] this config variable:
export GDK_PIXBUF_MODULE_FILE=${PREFIX}/lib/gdk-pixbuf-2.0/2.10.0/loaders.cache
[1] https://github.com/conda-forge/gdk-pixb ... ink.sh#L21
[2] https://github.com/AppImage/AppImageKit ... -GTK3-apps
looo
Postby looo » Thu Apr 18, 2019 3:46 pm
regarding dmgs:
not possible because qt5.6.3-packages are only available for linux. So we have to wait for qt5.12 migration which will come hopefully soon.
