Back port commits to 0.18 branch
sgrogan
Re: Back port commits to 0.18 branch
Postby sgrogan » Fri Jul 19, 2019 10:10 pm
looo wrote:
Fri Jul 19, 2019 7:50 pm
Thanks, I updated the 0.18 package which is available from conda-forge. Now the question is if we should go with the old (qt5.6) deps or if we should switch to new (qt5.9) deps. On osx qt5.9 is working better.
For win I still have problems with self compiled QT5.9 (because of the boost 1.7) so I used QT5.6
I would suggest using QT5.9. I'll update it when I get it working (I did see your pull request test)
I could also package directly from your win QT5.9 Conda Win build in a new conda env. This might be a good exercise, after this it should be easy to add it to the Travis weekly Conda builds.
uwestoehr
Postby uwestoehr » Fri Jul 19, 2019 11:33 pm
To me issue #4017 seems worth to be backported.
I have again a proposal 8-) :
I notice that bugs are immediately closed when the fix is in master. I think it would be good to keep them open until the fix was released or at least until it is also backported.
Users affected by a bug might search if it is a known one. If the bug report is closed you won't find it since you search if course for open bugs. So the status "closed" implies it is fixed while for the majority of users (using 0.18.x) it is not - yet.
wandererfan wrote:
Thu Jul 18, 2019 2:06 pm
wandererfan
Postby wandererfan » Sat Jul 20, 2019 12:28 am
Sounds reasonable to me. I'll see if I can figure out how to do it.
looo
Postby looo » Sat Jul 20, 2019 9:01 am
Yes, moving 0.18.3 to qt5.9 looks quite obvious to me. But as said I need come help from @triplus as I have no idea about the upload-scripts.
Yes, this would be nice addition.
sgrogan
Postby sgrogan » Sat Jul 20, 2019 6:55 pm
From which channel do I get the 0.18.3 build?
When I am successful with Win I will look at this, I need to understand for Win as above.
sgrogan
Postby sgrogan » Sat Jul 20, 2019 6:58 pm
Unfortunately we have published the 0.18.3 tag, so this will be part of 0.18.4.
kkremitzki
Postby kkremitzki » Sat Jul 20, 2019 6:59 pm
The stable PPA is updated btw.
looo
Postby looo » Sun Jul 21, 2019 6:33 am
Everything should be in conda-forge:
conda create -n freecad-0.18.3 freecad=0.18.3 -c conda-forge
sgrogan
Postby sgrogan » Sun Jul 21, 2019 6:22 pm
Thanks, should the WebGui work?
looo
Postby looo » Sun Jul 21, 2019 8:05 pm
You are right. Seems like qtwebengine is not supported in 0.18.3. In 0.19 it's automatically detected.
edit: this one is needed: https://github.com/FreeCAD/FreeCAD/comm ... 92a53c7291
