Appveyor is timing out
Re: Appveyor is timing out
I think this is the moment when I go out of the pond Archimides style crying aloud "Eureka":
https://travis-ci.org/FreeCAD/FreeCAD/jobs/527419405
If this ends ok, which I think it should.
The problem:
1. We have secrets in our Travis script.
2. The securing mechanism interferes somehow with msbuild.
3. This does not happen during PR, because PR are protected from accessing secrets.
Work-around - use "filter-secrets: false":
https://github.com/FreeCAD/FreeCAD/comm ... 364b04ef90
Isn't this a security hazard?
1. The flag "filter-secrets: false" is only set for windows builds.
2. No part of the windows execution path shows the content of the variables.
I do not see the security hazard, but please take a closer look and let me know if you see any concerns.
The problem:
Well, it seems that we have now travis windows builds running in 50 minutes with the help of clcache:
https://travis-ci.org/FreeCAD/FreeCAD/b ... tification
The tests are not working well yet (some appear not to run, but still they are reported as passing), but that thankfully can be tested in a branch with a PR.
Thanks for your hard work to get it running.abdullah wrote: ↑Fri May 03, 2019 7:09 am Well, it seems that we have now travis windows builds running in 50 minutes with the help of clcache:
Thanks for bearing with mewmayer wrote: ↑Fri May 03, 2019 8:53 amThanks for your hard work to get it running.abdullah wrote: ↑Fri May 03, 2019 7:09 am Well, it seems that we have now travis windows builds running in 50 minutes with the help of clcache:
PCH Part_GUI:
https://github.com/FreeCAD/FreeCAD/pull/2135
I am currently doing PCH for the Path WB.
Good work....wmayer wrote: ↑Fri May 03, 2019 8:53 amThanks for your hard work to get it running.abdullah wrote: ↑Fri May 03, 2019 7:09 am Well, it seems that we have now travis windows builds running in 50 minutes with the help of clcache:
I have added it:
https://github.com/FreeCAD/FreeCAD/pull/2136
I am not sure how it will work, because I had to put a second #ifdef block or it would not compile:
https://github.com/FreeCAD/FreeCAD/pull ... b81f16bd2f
Current PCH Status:
1. Part APP: In master - PCH Enabled
2. Part GUI: PR - PCH Not enabled in CMakeList.txt
3. PartDesign APP: In master - PCH Enabled
4. PartDesign GUI: In master - PCH Not enabled in CMakeList.txt
5. Sketcher APP: In master - PCH Enabled
6. Sketcher GUI: In master - PCH Not enabled in CMakeList.txt
7. Path APP: PR - PCH ENABLED in CMakeList.txt
8. Path GUI: PR - PCH Not enabled in CMakeList.txt
I won't be able to work for FreeCAD in the following days.
I can move headers as I have done, but I cannot reasonably test PCH impact without overloading the PR/CI system. I do not know if you are interested in deciding on whether to enable them or not depending on whether it makes sense or not.
For the rest of WBs, I can move headers as I have done for these when I am back.
apeltauer wrote: ↑Fri May 03, 2019 12:29 pmGood work....wmayer wrote: ↑Fri May 03, 2019 8:53 amThanks for your hard work to get it running.abdullah wrote: ↑Fri May 03, 2019 7:09 am Well, it seems that we have now travis windows builds running in 50 minutes with the help of clcache:
