Appveyor is timing out
bernd
Re: Appveyor is timing out
Postby bernd » Sat May 18, 2019 12:18 pm
abdullah
Postby abdullah » Sat May 18, 2019 12:27 pm
git commit 06fffbd
Ok. I will them substitute mine with yours when I rebase ;) :
https://github.com/FreeCAD/FreeCAD/pull ... f16cb2e57b
abdullah
Postby abdullah » Sat May 18, 2019 4:36 pm
This is the first failing file:
https://github.com/FreeCAD/FreeCAD/blob ... athPost.py
I do not see anything that may be disturbing Travis.
This is the log without it:
https://travis-ci.org/FreeCAD/FreeCAD/jobs/534190818
This is the log with it:
https://travis-ci.org/FreeCAD/FreeCAD/jobs/534151312
When it is included, the output of previous Path tests is not even there, it shows the error:
TestPathApp (unittest.loader._FailedTest) ... ERROR
Any idea is very much welcome.
abdullah
Postby abdullah » Sun May 19, 2019 10:37 am
I made a mistake yesterday during the search for the tests that failed. I enabled one test that is commented out in master.
I am doing a kind of binary search of this tests:
from PathTests.TestPathLog   import TestPathLog
from PathTests.TestPathCore  import TestPathCore
#from PathTests.TestPathPost  import PathPostTestCases
from PathTests.TestPathGeom  import TestPathGeom
from PathTests.TestPathOpTools  import TestPathOpTools
from PathTests.TestPathUtil  import TestPathUtil
from PathTests.TestPathDepthParams        import depthTestCases
from PathTests.TestPathDressupHoldingTags import TestHoldingTags
from PathTests.TestPathDressupDogbone import TestDressupDogbone
#from PathTests.TestPathStock import TestPathStock
#from PathTests.TestPathTool import TestPathTool
#from PathTests.TestPathTooltable import TestPathTooltable
#from PathTests.TestPathToolController import TestPathToolController
#from PathTests.TestPathSetupSheet import TestPathSetupSheet
#from PathTests.TestPathDeburr  import TestPathDeburr
The first "paragraph" passes. The second paragraph (including all four tests) fails. I am running the build with the first two tests of this second paragraph enabled here:
https://travis-ci.org/FreeCAD/FreeCAD/jobs/534406889
abdullah
Postby abdullah » Sun May 19, 2019 6:19 pm
This test is failing in Travis Windows:
https://github.com/FreeCAD/FreeCAD/blob ... ingTags.py
Any idea why it could be?
abdullah
Postby abdullah » Tue May 21, 2019 6:40 pm
I think I am becoming insane.
This:
https://github.com/FreeCAD/FreeCAD/blob ... PathApp.py
does not fail.
This:
fails.
To me it is the same content.
I do not know Python enough, but these tests do not provide much information when they fail. That is not very convenient...
sgrogan
Postby sgrogan » Tue May 21, 2019 9:50 pm
I don't see the difference, but python is sensitive to tabs/spaces.
You might want to weigh in on these threads
https://forum.freecadweb.org/viewtopic.php?f=18&t=35428
https://forum.freecadweb.org/viewtopic.php?f=10&t=36515
"fight the good fight"
abdullah
Postby abdullah » Wed May 22, 2019 12:05 pm
Thanks for weighing in.
I am going to continue doing tests, but I go blind...
abdullah
Postby abdullah » Wed May 22, 2019 12:32 pm
wmayer wrote:...ping...
I think I might have found the culprit of the Path tests failing. Indirectly loading the Gui.
The test that now fails:
imports:
PathScripts.PathDressupHoldingTags
which imports:
import PathScripts.PathDressup
https://github.com/FreeCAD/FreeCAD/blob ... Dressup.py
which imports and uses the GUI:
import FreeCAD
import FreeCADGui
import PathScripts.PathJob as PathJob
def selection():
    '''isActive() ... return True if a dressup command is possible.'''
    if FreeCAD.ActiveDocument:
        sel = FreeCADGui.Selection.getSelectionEx()
        if len(sel) == 1 and sel[0].Object.isDerivedFrom("Path::Feature") and PathJob.Instances():
            return sel[0].Object
    return None
def hasEntryMethod(path):
    '''hasEntryDressup(path) ... returns true if the given object already has an entry method attached.'''
    if 'RampEntry' in path.Name or 'LeadInOut' in path.Name:
        return True
    if 'Dressup' in path.Name and hasattr(path, 'Base'):
        return hasEntryMethod(path.Base)
return False
I am not sure if the tests/code is suitable for a console mode testing.
I am not sure if we should only execute the tests in Gui mode (which makes them quite worthless for CI testing), or if we should think in rewritten them... what do you think?
Site Admin
Postby wmayer » Wed May 22, 2019 12:43 pm
I think the test should be adjusted to be callable from command line mode.
