Directly control inputfield units
sliptonic
Postby sliptonic » Sun May 12, 2019 7:50 pm
Can I explicitly (from Python) set the displayed units of a inputfield? For example, if the user has Standard units set for their UI default and a field is showing '6.35 mm' can I change the unit for that one field so it shows '0.25 in'?
Site Admin
Re: Directly control inputfield units
Postby wmayer » Sun May 12, 2019 8:50 pm
You can change the quantity type, the format of how floats should be displayed or the number of decimals but you cannot change the unit scheme. At the moment this always follows on what is set in the preferences.
In order to support this the InputField class must be adjusted. Feel free to open a feature request.
sliptonic
Postby sliptonic » Sun May 12, 2019 9:37 pm
Thank Werner,
I created an issue https://www.freecadweb.org/tracker/view.php?id=3966
I accidentally created in the Path project and I don't seem to have authority to move it someplace more appropriate. If necessary, I'll delete and recreate.
Postby chrisb » Sun May 12, 2019 9:55 pm
I have a move button and moved it to the general FreeCAD section.
