Translating external workbenches
EdgarRobles
Re: Translating external workbenches
Postby EdgarRobles » Sun Dec 22, 2019 10:39 pm
Hi FreeCAD team,
I trying to translate Dodo workbench https://github.com/oddtopus/dodo i have made whole procedure described on this page https://www.freecadweb.org/wiki/Transla ... _workbench without success.
This is what i have done:
-Edit some test code in order to generate one .ts file. I successfully made it through pyside2-lupdate command on windows 10.
-Made a translations folder behind InitGui.py dodo workbench file and es_ES.ts and es_ES.qm files inside.
-addtranslationpath function point to translation folder at the right way and its placed at the begining in InitGui.py .
Freecad load dodo workbench with this changes without errors.
I'm not sure what a missing.
OS: windows 10
Version: 0.18.16117
Branch: releases/FreeCAD-18
Hash: dbb4cc6415bac848a294f03b80f65e888d531742
Python version: 3.6.6
Qt version: 5.6.2
OCC version 7.3.0
Locale: english/UnitedStates (en_US)
InitGui.py file
class dodo ( Workbench ):
  import DraftSnap
  import sys, FreeCAD,os,dummyos
  from PySide.QtCore import QT_TRANSLATE_NOOP
  FreeCADGui.addLanguagePath(os.path.join(dummyos.relpath,"Resources"+os.sep+"translations"))
  FreeCAD.Console.PrintMessage(os.path.join(dummyos.relpath,"Resources"+os.sep+"translations"))
ES_es.ts
<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE TS>
<TS version="2.1" language="es">
<context>
    <name>FrameBranchManager</name>
    <message>
        <location filename="CFrame.py" line="374"/>
        <source>FrameBranch Manager</source>
        <translation type="unfinished"></translation>
    </message>
    <message>
        <location filename="CFrame.py" line="377"/>
        <source>Open FrameBranch Manager</source>
        <translation>Abre gestor de marcos</translation>
    </message>
</context>
<context>
    <name>adjustFrameAngle</name>
    <message>
        <location filename="CFrame.py" line="281"/>
        <source>adjustFrameAngle</source>
    </message>
    <message>
        <location filename="CFrame.py" line="284"/>
        <source>Adjust the angle of frame by two edges</source>
        <translation>Adjuste del angulo del marco por medio de dos aristas</translation>
    </message>
</context>
<context>
    <name>alignEdge</name>
    <message>
        <location filename="CFrame.py" line="209"/>
        <source>Mate the edges</source>
    </message>
    <message>
        <location filename="CFrame.py" line="212"/>
        <source>Join two edges: select two or pre-select several</source>
        <translation>Une dos aristas:selecciona dos o pre selecciona varias</translation>
    </message>
</context>
<context>
    <name>alignFlange</name>
    <message>
        <location filename="CFrame.py" line="115"/>
        <source>alignFlange</source>
    </message>
    <message>
        <location filename="CFrame.py" line="118"/>
        <source>Rotates the section of the beam to make the faces parallel to another face</source>
    </message>
</context>
<context>
    <name>dodo</name>
    <message>
        <location filename="InitGui.py" line="155"/>
        <source>Frame tools</source>
    </message>
    <message>
        <location filename="InitGui.py" line="156"/>
        <source>Pype tools</source>
    </message>
    <message>
        <location filename="InitGui.py" line="157"/>
        <source>Utils</source>
    </message>
    <message>
        <location filename="InitGui.py" line="158"/>
        <source>QkMenus</source>
    </message>
</context>
<context>
    <name>extend</name>
    <message>
        <location filename="CFrame.py" line="266"/>
        <source>extendTheBeam</source>
    </message>
    <message>
        <location filename="CFrame.py" line="269"/>
        <source>Extend the beam either to a face, a vertex or the c.o.m. of the selected object</source>
    </message>
</context>
<context>
    <name>frameIt</name>
    <message>
        <location filename="CFrame.py" line="44"/>
        <source>Place one-beam over one-edge</source>
    </message>
    <message>
        <location filename="CFrame.py" line="47"/>
        <source>Place one beam after the other over the edges</source>
    </message>
</context>
<context>
    <name>insertPath</name>
    <message>
        <location filename="CFrame.py" line="318"/>
        <source>insert Path</source>
    </message>
    <message>
        <location filename="CFrame.py" line="363"/>
        <source>Creates one path along selected edges</source>
    </message>
</context>
<context>
    <name>insertSection</name>
    <message>
        <location filename="CFrame.py" line="388"/>
        <source>Insert sections</source>
    </message>
    <message>
        <location filename="CFrame.py" line="394"/>
        <source>Creates customized beam profiles 2D</source>
    </message>
</context>
<context>
    <name>levelBeam</name>
    <message>
        <location filename="CFrame.py" line="176"/>
        <source>Flush the surfaces</source>
    </message>
    <message>
        <location filename="CFrame.py" line="179"/>
        <source>Shift the beams to line-up the faces to the first selection (faces must be //)</source>
    </message>
</context>
<context>
    <name>pivotBeam</name>
    <message>
        <location filename="CFrame.py" line="227"/>
        <source>pivotTheBeam</source>
    </message>
    <message>
        <location filename="CFrame.py" line="230"/>
        <source>Rotates the beam around an axis (edge or center-of-curvature)</source>
    </message>
</context>
<context>
    <name>reverseBeam</name>
    <message>
        <location filename="CFrame.py" line="83"/>
        <source>Reverse orientation</source>
    </message>
    <message>
        <location filename="CFrame.py" line="100"/>
        <source>Reverse the orientation of selected objects</source>
    </message>
</context>
<context>
    <name>rotJoin</name>
    <message>
        <location filename="CFrame.py" line="300"/>
        <source>rotJoinEdge</source>
    </message>
    <message>
        <location filename="CFrame.py" line="303"/>
        <source>Rotates and align the beam according another edge</source>
    </message>
</context>
<context>
    <name>shiftBeam</name>
    <message>
        <location filename="CFrame.py" line="143"/>
        <source>shiftTheBeam</source>
    </message>
    <message>
        <location filename="CFrame.py" line="146"/>
        <source>Translate objects by vectors defined on existing geometry</source>
    </message>
</context>
<context>
    <name>spinSect</name>
    <message>
        <location filename="CFrame.py" line="63"/>
        <source>Spin beams by 45 deg.</source>
    </message>
    <message>
        <location filename="CFrame.py" line="66"/>
        <source>Rotates the section of the beam by 45 degrees</source>
    </message>
</context>
<context>
    <name>stretchBeam</name>
    <message>
        <location filename="CFrame.py" line="249"/>
        <source>stretchTheBeam</source>
    </message>
    <message>
        <location filename="CFrame.py" line="252"/>
        <source>Changes the length of the beam, either according a preselected edge or a direct input</source>
    </message>
</context>
</TS>
main.pro
SOURCES = CFrame.py InitGui.py fCmd.py CPipe.py CUtils.py dodoDialogs.py dodoPM.py fForms.py fObservers.py
TRANSLATIONS =  ES_es.ts
Postby Kunda1 » Fri Jan 17, 2020 11:27 am
Alternative Translation method for FreeCAD Addons? https://forum.freecadweb.org/viewtopic.php?f=10&t=42516
alex.zhang
Postby alex.zhang » Wed Feb 19, 2020 2:54 pm
@yorik
I am trying to translate BIM workbench to Chinese and almost done.
There are several problems.
1. Move to trash menu still display English.
BimCommands.py
class BIM_Trash:
    def GetResources(self):
        return {'Pixmap'  : os.path.join(os.path.dirname(__file__),"icons","BIM_Trash.svg"),
                'MenuText': QT_TRANSLATE_NOOP("BIM_TogglePanels", "Move to Trash"),
                'ToolTip' : QT_TRANSLATE_NOOP("BIM_TogglePanels", "Moves the selected objects to the Trash folder"),
                'Accel': 'Shift+Del'}
2. Welcome screen dialog(dialogWelcome.ui), views dialog(dialogViews.ui) and status icon still display English.
InitGui.py
        if FreeCAD.ParamGet("User parameter:BaseApp/Preferences/Mod/BIM").GetBool("FirstTime",True) and (not hasattr(FreeCAD,"TestEnvironment")):
            todo.delay(FreeCADGui.runCommand,"BIM_Welcome")
        todo.delay(BimCommands.setStatusIcons,True)
3. I cannot find where "BIM Views manager" is, which is shown in toolbar context menu, please see attached 1.png.
4. Even I set language to Chinese, BIM workbench require changing to another language and back to Chinese for the translation to work. Is there a work around?
BTW, I confirm that all strings are translated and included in ts and qm file.
Thanks.
kkremitzki
Postby kkremitzki » Wed Feb 19, 2020 7:03 pm
谢谢! (Thank you! for helping with translation.)
Postby Kunda1 » Sun Feb 23, 2020 11:18 pm
Can we please figure out why translations aren't working for external workbenches? :(
alex.zhang
Postby alex.zhang » Mon Feb 24, 2020 2:33 pm
Is there any approach? I checked the ts file and sure the translated words are there. The ts file is released to qm file.
Thanks.
Postby Kunda1 » Mon Feb 24, 2020 2:40 pm
Should be explained in Translating_an_external_workbench
But I don't know the details of where the problem is
marmni
Postby marmni » Mon Feb 24, 2020 4:31 pm
"Can we please figure out why translations aren't working for external workbenches?"
I was able to load translation for PCB WB. Put FreeCADGui.addLanguagePath("") just after Initialize() def.
def Initialize(self):
        FreeCADGui.addLanguagePath(":/data/translations")
However in "InitGui.py" code
FreeCAD.Console.PrintMessage(translate("PCB", "InitGui") + "\n")
print(translate("PCB", "InitGui"))
def Initialize () returns "InitGui", but def Activated () returns correct translation.
