FEM unit test failure in Cmd mode
bernd
Post by bernd »
I have the following unit test failure which I am really strugle with to reproduce outside of the unit test. As a start point I would like to know if others can reproduce this?
- start FreeCADCmd (it ONLY happens in Cmd!)
- run code ...
import unittest
unittest.TextTestRunner().run(unittest.TestLoader().loadTestsFromName("femtest.testccxtools.TestCcxTools.test_1_static_analysis"))
output:
Constraint fixed: FemConstraintFixed
  Finite element mesh nodes will be retrieved by searching the appropriate nodes in the finite element mesh.
  ReferenceShape ... Type: Face, Object name: Box, Object label: Box, Element name: Face1
Unexpected error when writing CalculiX input file: <class 'TypeError'>
E
ERROR: test_1_static_analysis (femtest.testccxtools.TestCcxTools)
  File "/home/hugo/Documents/dev/freecad/freecadbhb_dev/build/Mod/Fem/femtest/testccxtools.py", line 143, in test_1_static_analysis
    error = fea.write_inp_file()
  File "/home/hugo/Documents/dev/freecad/freecadbhb_dev/build/Mod/Fem/femtools/ccxtools.py", line 650, in write_inp_file
    self.inp_file_name = inp_writer.write_calculix_input_file()
  File "/home/hugo/Documents/dev/freecad/freecadbhb_dev/build/Mod/Fem/femsolver/calculix/writer.py", line 113, in write_calculix_input_file
    self.write_calculix_one_input_file()
  File "/home/hugo/Documents/dev/freecad/freecadbhb_dev/build/Mod/Fem/femsolver/calculix/writer.py", line 143, in write_calculix_one_input_file
    self.write_node_sets_constraints_fixed(inpfile)
  File "/home/hugo/Documents/dev/freecad/freecadbhb_dev/build/Mod/Fem/femsolver/calculix/writer.py", line 501, in write_node_sets_constraints_fixed
    self.get_constraints_fixed_nodes()
  File "/home/hugo/Documents/dev/freecad/freecadbhb_dev/build/Mod/Fem/femsolver/writerbase.py", line 133, in get_constraints_fixed_nodes
    femobj
  File "/home/hugo/Documents/dev/freecad/freecadbhb_dev/build/Mod/Fem/femmesh/meshtools.py", line 48, in get_femnodes_by_femobj_with_references
    node_set = get_femnodes_by_references(femmesh, femobj['Object'].References)
  File "/home/hugo/Documents/dev/freecad/freecadbhb_dev/build/Mod/Fem/femmesh/meshtools.py", line 84, in get_femnodes_by_references
    references_femnodes += get_femnodes_by_refshape(femmesh, ref)
  File "/home/hugo/Documents/dev/freecad/freecadbhb_dev/build/Mod/Fem/femmesh/meshtools.py", line 110, in get_femnodes_by_refshape
    nodes += femmesh.getNodesByFace(r)
TypeError: argument 1 must be Part.TopoShape, not Part.Face
Ran 1 test in 0.045s
FAILED (errors=1)
<unittest.runner.TextTestResult run=1 errors=1 failures=0>
As I tried for two hours already, I may give more informations later on ...
bernd
Re: FEM unit test failure in Cmd mode
Post by bernd »
The method does not accept a Part.Face but would like to have a Part.TopoShape instead. A Part.Face is a Part.TopoShape! Or am I wrong?
Founder
Post by wmayer »
No failure with version 0.19R16784 or 0.19R16810
PaulG
Post by PaulG »
No failure on 0.18.1 or 0.19R16786 on Mint 18.1 xenial with python 2.
looo
Post by looo »
No failure with: 0.19.16793 py3.7.1 qt5.6.3
bernd
Post by bernd »
tested again. it fails for me on self compiled 0.19.16810 on debian buster on FreeCADCmd, it does not fail on installed FreeCAD. I will do a fresh rebuild, if it does not help I try a VM of fresh Debian an FreeCAD.
By the use of vagrant this runs while haveing a beer :mrgreen:
bernd
Post by bernd »
Founder
Post by wmayer »
When reformatting the code to for easier testing it still works OK:
active_doc=App.newDocument()
box = active_doc.addObject("Part::Box", "Box")
fixed_constraint = active_doc.addObject("Fem::ConstraintFixed", "FemConstraintFixed")
fixed_constraint.References = [(box, "Face1")]
active_doc.recompute()
import Fem
ref = fixed_constraint.References[0]
femmesh = Fem.FemMesh()
from femmesh.meshtools import get_femnodes_by_refshape as getnodes
getnodes(femmesh, ref)
bernd
Post by bernd »
I tried this before werner, but it does not fail if I use the code this way. It only fails inside the unit test, only in cmd mode only on my Debian only if self compiled.
In a new Debian testing virtual machine it does not fail.
Mhh I made a fresh build yesterday but it still fails.
bernd
Post by bernd »
I collected all informations in last commit on branch https://github.com/berndhahnebach/FreeC ... femunitcmd (ATM: https://github.com/berndhahnebach/FreeC ... it/344110e)
code to run on my computer in FreeCADCmd:
import unittest
unittest.TextTestRunner().run(unittest.TestLoader().loadTestsFromName("femtest.testcmdproblem.TestCmdProblem.test_cmdproblem"))
error output:
>>> import unittest
>>> import TestCmdProblem
(<Part::PartFeature>, ('Face1',))
<Face object at 0x55615290c8c0>
<class 'Part.Face'>
Face
E
ERROR: test_cmdproblem (femtest.testcmdproblem.TestCmdProblem)
  File "/home/hugo/Documents/dev/freecad/freecadbhb_dev/build/Mod/Fem/femtest/testcmdproblem.py", line 65, in test_cmdproblem
  File "/home/hugo/Documents/dev/freecad/freecadbhb_dev/build/Mod/Fem/femmesh/meshtools.py", line 114, in get_femnodes_by_refshape
Ran 1 test in 0.008s
FAILED (errors=1)
on (copied from FreeCAD Gui) but same build:
OS: Debian GNU/Linux 10 (buster) (KDE/plasma)
Version: 0.19.16810 (Git)
Build type: Unknown
Hash: fc37053210d2abc058c6e14b06d7b8e28aeee8ea
Python version: 3.7.3rc1
Qt version: 5.11.3
Locale: German/Switzerland (de_CH)
